Oneway Talon/Stronghold Adapters
>I thought the adapters were interchangable between these two chucks but evidently they are not. The adapter for the Powermatic 90 is listed as supporting the Stronghold only. I didn't get and answer from Oneway (they must be closed) and thought someone here may know??
Re: Oneway Talon/Stronghold Adapters
Bob Elliott
>Stronghold and Talon/original Oneway chuck adaptors are not interchangeable. The Stronghold adaptor is held on with 4 bolts. The Talon /original Oneway adaptors are held on with 3 bolts. Talk to Oneway, they can tell you if they can do a custom adaptor if it's not a stock item.
Alternatively, you can go to the Oneway discussion group and post your question. Kevin from Oneway frequently provides answers and you could get your answer before Monday.
Thanks, Bob.
Richard Allen
Richard Allen
>Oneway uses a taperlock adaptor. Both the Stronghold and the Talon adaptors use 2 screws to set the taperlock. The adaptor used for the Talon is smaller than the adaptor used for the Stronghold. There isn't enough diameter in the talon taperlock adaptor to make 1 1/2" threads.
Good Luck
>Thanks, Richard. I'm seriously considering the Stronghold, especially since I can use smaller jaws as needed.
Stronghold has only two screws...
Peter Teubel
>...holding the adapter in. The Talon has 3.
Re: Stronghold has only two screws...
Bob Elliott
>Peter,
You are correct, two bolts. I guess what I meant to say is that there are holes drilled every 90 degrees. The other two holes are for jack screws used in the adaptor removal process.
Rob Steinle
>Check with Oneway about using a spindle adaptor to make the thread conversion between your headstock and a taper adaptor that fits your chuck. Perhaps some trade-off's, but less expensive then a new chuck
