Jars!
Jars!
Jars!
e
>a new shape i'm playing with -- inspired from works at the Asian Art Museum of San Francisco --
camphor and cedar ... ~5"h & 8"h ...
Re: Jars!
Re: Jars!
Carole in VA
>Darn it e, how do you hollow the base on those things with that long skinny neck? I have been fiddling with that and just can't for the life of me figure out a way to do it and the next thing I know, you go and post pics of two beautiful ones!! :) What is the wall thickness?
Re: Jars!
Re: Jars!
George Van in WI
>Very nice idea, these look great. I like the finish you chose, it makes the jars look usable. Were these turned green?
Re: Jars!
Re: Jars!
>Those don't look like "Jars". They look like vases. Whatever you call them, they sure look good!
Re: Jars!
Steven Antonucci
Very gourd-like!
steve antonucci
>When you hollow with such a long neck, do you turn the speed way down to lower the risk of cracking the neck (longer time spent in the form though) or leave it higher (faster cleaner cuts)?
I've cracked the neck in just about every one of those I've ever made...
Steve
Re: Jars!
Re: Jars!
RevDoug
>e, very cool. I'm looking forward to your response to the above questions. Love what you've done with these and would like to give it a "whirl." Hollow turning is still pretty new with me, so I'm trying to learn all I can. Thanks for sharing these with us.
Turn 'em round,
Re: Jars!
Re: Jars!
Eduardo Sarmiento Hall-Lima Peru
>Well done ,I have seen this hollow out from the bottom,then you make the neck as thick and long as you like,then just plug the bottom and presto,
Re: Jars!
Re: Jars!
e
>hi carole:
the wall thickness is less than 1/4".
look at the jars as hollow forms made upside-down & inside-out. the neck-to-be is chucked-up and later turned into a neck-shape after hollowing; hollowing is completed from the bottom.
but just as in a hollow-form where a small-holed collar or neck is added, a section of wood is parted off before hollowing. later, this bottom section is re-inserted as the foot, matching the grain and making the join-line appear as a part of the turning.
hope this makes sense but if it doesn't, let me know.
Re: Jars!
thanks to everyone for your response
e
>hope my above-posted explanation is clear enough to answer all your questions -- but if not, let me know.
e
Re: Jars!
Re: Jars!
Carole in VA
>Ah ha! I knew there was no way to get any kind of hollowing tool down that neck and into the bulb...duh! Thanks for the "how to", e. They are really beautiful.
Re: Jars!
Re: thanks to everyone for your response
tek-Brunswick, Ohio
>Very cleaver technique! We just have to be smarter than the inanimate wood. e- you proved that you are. Maybe some day I can outsmart the wood also. Very good looking turnings too!
Tom
Re: Jars!
Re: Jars! - very clever!
