Re: Grind Angles please
gary guenther
>Hi Jim
This won't be the simple answer you want, but maybe it'll get you started in the right direction.
I've seen people (even one person) use quite different angles on the same tools depending on their personal preferences and on exactly what their particular application might be for that particular tool (e.g., inside a bowl, outside a bowl, hollowing, face grain vs. end grain, etc.).
If you look at the left side of the main WC page, in the reddish brown menu area, and go down to the "Odds n Ends" section near the bottom, you will see a link for the 'Tool Grinds Library'. You'll probably find some interesting info in there. It's not definitive, however, because, again, everyone has their own preferences.
I've typically been using larger angles, but at a recent CAW meeting, I saw Dick Sing using a spindle gouge at 40 degrees, and I'm going to try it to see what it's like. [As an example of tool control, he did a goblet about 6" long that couldn't have been more than 2-3 mm in diameter, and it had a large number of captive rings on it! See attached photo of goblet and tool.]
Regards,
Gary
