Powermatic 90 electrical info
>Can anyone tell from this photo if I can change this setup from its current 110v/120v to a 220v. I just picked this up and would like to convert it to 220v (I think) because I've been told the 220v will run stronger/better???
Re: Powermatic 90 electrical info
tdaniel
>you will have exactly the same horsepower with either the 110 or the 220. The 220 may start slightly faster but once running you will have the same horsepower if your wiring is large enough. 220 will run better if the wiring is too small.
>So now I'm curious. What are the advantages of a 220 motor vs a 110 motor? My combo machine has 3 motors in it and runs on 220. Why did they do that instead of 110?
Sam Dean
>At 220 volts it takes half the amperage than 120 volts to run the same device. If your combo machine takes 20 amps of 220 volt power, it would take 40 amps at 120 volt power. Most 120 volt lines aren't sized to handle that much load, so 220 volt is the better choice. (like what Terry said about the lines being large enough). If your lines are properly sized, and the motor isn't over about 2 horsepower, than you might as well stick with 120 volt because it won't gain you anything to upgrade. Hope that helps.
Thanks,
Sam
A great help! Thanks All.
