We value your privacy.
>After reading Russ Fairfield's link in the thread below I learned that a chuck is not a necessity for turning. Evidently, using a chuck provides convenience & speed but isn't required for fine work.
Can anyone recommend a book(s) that detail how to maximize the use of a faceplate for woodturning?
>I have found that a lot of the older books have lots of good techniques for faceplate turning. Many of these books were published before chucks were as commonly available as they are today. You can often find good deals on these older books on eBay. I found some at my local library as well. I believe there might be some articles right here on WC about using glue blocks on faceplates.
>There are lot of options with a face plate. This is from an old article that describes some of them.
There are two (2) basic ways to attach a piece of wood to a faceplate, either directly with screws into the wood, or by attaching a waste-block to the wood and then attaching the faceplate to the waste-block with screws. A 4” diameter faceplate is sufficient for almost any piece of wood up to about 12” diameter. We could always use a larger faceplate, but the extra glue area is unnecessary for most pieces, and the larger plate may force us to make the base of a bowl too large for best appearance.
Both surfaces, the wood and the waste-block, must be flat for a good glue joint. Some use a hand plane to do this. Some use a power plane, a router, or the lathe.
The wood can be held between centers while the flat place on the bottom is made for the waste-block. The outside of the form can also be turned while it is between centers. Knock the center nib off to below the surface with a wood chisel.
The wood may be held against the faceplate with the tail-center while the base is turned. If slippage is a problem, we can use a “prickle plate” attached to the faceplate. This is a plywood disc that has a large number of nails or screws driven through to the same depth from its backside. The top of the wood is held against the plate with the tailstock while the bottom is turned flat to accept a waste-block. Again, the outside of the form can be turned at the same time
Almost any wood glue can be used to attach the waste-block. Some prefer epoxy, others polyurethane, Titebond, slow curing gap-filling CA glues, or hot-melt glues. Poly glue (Gorilla) and epoxy is the best for filling gaps between the surfaces. CA glue is the least tolerant of gaps.
If the wood is green and wet, it can be dried on the surface with a heat gun or hair dryer to allow for a glue joint. The wood will have to be turned before the moisture can migrate back into the glue joint. The water resistance of Titebond-2 or Poly are beneficial.
If both surfaces are flat, the waste-block can be held to the wood with a paper glue joint. This joint can be separated with a wood chisel after the turning is completed.
If the wood surface is flat, it can be attached directly to the steel faceplate with “double stick” carpet tape, but a larger 6” faceplate is recommended to provide additional surface area, and the fiberglass cloth tape is recommended.
And, as an alternative, there isn’t a salad sized bowl that can’t be turned between centers, all the way. The only problem will be the long center stem that has to be removed.
>Since my book has been quoted and my name mentioned, I guess I should chime in on this. Russ is correct, as usual, a chuck is not necessary to turn bowls or hollow forms. I personally use a chuck because they are convenient and faster to use than faceplates and I have about a dozen of them. However, a well mounted piece on a faceplate will be a more solid mount than any chuck. I say well mounted, because in the case of hollow forms it is not good practice to screw directly into end grain. The screws are likely to work loose.
When using faceplates, I prefer to use a good solid piece of wood as a waste block that is glued to the base of the bowl blank and the faceplate is screwed directly to the waste block. The grain of the waste block must be perpendicular to the axis of rotation so that the screws have both end grain and side grain holding them. I've always used Tite-Bond II glue for my wood glue joints. To date, I've never had a Tite-Bond II glue joint break. I've had the wood break, but the glue held. I can't say that for any other glue.
Many people use hot melt glue to mount the bowl blank to the waste block and at least a few melt the hot melt glue in a pot and dip the faceplate into the hot glue then apply it directly to the bowl blank with some form of pressure to ensure the faceplate surface is flat against the blank. An application of heat from a hair dryer or some other means helps to release the glue after you are done turning the vessel.
My book, A Guide to Work-Holding on the Lathe, should also be a good reference to have in your library since it discusses almost every method of holding wood on the lathe.
>I understand using a waste block on end grain has a problem with screws working loose. Has anyone tried using pocket screws to attach the waste block to the end grain. The screws go across the end grain at an angle rather than straight in. I would think they would hold better.
>Chucks are a relatively recent invention. Look at the catalogs of 50 yrs. ago, and see what you can find. Look at the books, and see the descriptions of the chucks they had 100 yrs. ago.
There were no live centers, but fixed or 'dead' centers - you had to use grease on them. Bowl gouges and some other tools that you take for granted today were not available. Lots of turners made their own tools, which is still being done in other parts of the world. Matter of fact, some make their own lathes.
VFD (variable frequency drive) consisted of telling the kid pumping the pedal to go faster, or slow down.
We are blessed with modern technology. Which one day our children are going to laugh at us, while they guide the gouge with a joystick, or even by moving their eyes or nose. Or maybe a robot will do it for them. Or some newer version of CNC.
Don't laugh... we never considered that someday we would carry a Dick Tracy phone around.
>I've always read about using dowels. I usually just squirt a little CA in the hole before putting the screws in. This has worked great for me especially on punky wood.
