3520
W.C. Turner
>I just discovered today that my VFD ac inverter box on my 3520a gets very hot in a short period of time. Is this normal?
Thanks,
W.C.
3520
W.C. Turner
Thanks,
W.C.
Re: 3520
Phil in NJ
>VFD's are not 100% efficient. I think the number is typically 90%. The rest is lost as heat.
The VFD on my Oneway has a big heatsink and a fan...
So long story short, it is normal-- and if it is a decent VFD at all it will protect itself from getting too hot.
Look up the manual for whatever VFD you have (Yaskawa? Hitachi?) online to confirm the details.
Re: 3520
W.C. Turner
>mine's a Delta
Re: 3520 *LINK*
Gerry in Maryland
>Here's a link if you want to get the maual for your VFD.
Gerry
Delta VFD's
Thanks
W.C. Turner
>Gerry for the link.
Tks Phil.
Re: 3520
Harry Ludke
>When I'm not using my 3520 for extended periods of time, I make a habit of flipping the circuit breaker. This way the inverter box is off. As you know, the red on/off switch on the front of the lathe does not turn off the inverter box.
The added advantage of turning off the lathe at the breaker box is that it helps protect the inverter from power spikes. This is especially important in the summertime when we can have some extremely violent thunderstorms and lightning role through our area.
Maybe I'm being paranoid, and maybe it's overkill, but it sure makes me feel more comfortable.
Re: 3520
Bob Persing (Skillman NJ)
>WC,
I'm not sure what you mean by very hot and how short is short but, the VFD on my 3520a does not get so hot that I cannot place my hand on the heatsink. It should say that I am usually not a very agressive turner, rarely hogging of lots of wood in a single pass...maybe in the future.
If you want me to provide a better assesment of how "hot" my VFD gets, let me know. I guess I could measure it soem how.
BobP
Re: 3520
>I think Harry's idea to disconnect power to the 3520 when not in use is good. I purchased a disconnect switch at Lowes for about $15 and put it just above the 220V recepticle for the lathe. I think it was rated for 60A and has a lever handle on the side...easy and convenient to use. It just so happened to be a "fused" type (they did not have the non-fused version) so I put a pair of 20A fuses in it.
BobP
I always...
W.C. Turner
>unplug my 3520 when not in use. When I noticed it being hot, I had a book, that the cover extended over the vfd. That might have made it seem hotter than usual. "How hot is hot"? I could lay my hand on top of it, but, it was a little uncomfortable. It wasn't hot enough to start a fire though. I check it again, without anything on top of it to block ventilation, & report on it.
Thanks,
W.C.
