Tool gloat #2
Tool gloat #2
Tool gloat #2
tek-Brunswick, Ohio
>It's nice to have a son-in-law that is a tool and die maker! He made me this boring bar. It is a 3/4" diameter bar with a 3/8" hole bored in the end. There are two setscrews to hold the cutter and the other end is sized down to fit in my Kelton Handle. The bit in it is a 3/8" ball end mill. The end mill has been one of my favorite cutters since Jim Pugh taught me how to use it.
Tom
Re: Tool gloat #2
Re: Tool gloat #2
Eduardo Sarmiento Hall-Lima Peru
>Hey thas great tell me how to use the bit Ill love to know here in lima I can get them by the dozen
Re: Tool gloat #2
Re: Tool gloat #2
John Trant (Baltimore/DC corridor)
>Use it just like you would if it were a bowl gouge. For those that may not know, the bit is a ball nose end mill.
John
Re: Tool gloat #2
Re: Tool gloat #2
tek-Brunswick, Ohio
>They are great to hollow with. Cut with the edge on the left side. You can use the edge horizontal, which is more aggressive. If you roll the tool a little counter clockwise it takes more of shearing cut. The size we use is the 3/8". They are a lot less expensive than most turning tools, and they are high-speed steel. I've seen the work you do. I'm sure you'll pick up the technique right away.
Tom
