A little Box
tek-Brunswick, Ohio
>I tried an experiment with dying this piece. I like the results. What do you think? The box is 3'H x 1 5/8W, spalted maple, dyed with alcohol aniline (transfast) dye. Comments welcome on the form and finish.
Tom
A little Box
tek-Brunswick, Ohio
Tom
Re: A little Box
Rick Allen
>Hi Tom
I also like it.
Is there anything in the process you might do differently? Or is there anything in the process which opened up posiblities for other turning activities for you? For example you used the alcohol aniline (transfast) dye on spalted maple. Are you encouraged that this will work well on other woods?
Thanks
Richard
Re: A little Box
tek-Brunswick, Ohio
>I've used the dye before and wiped it on pieces. This is my second experiment on letting it soak into the wood by capillary action. I put the lower end of the box blank in about an inch of dye and let the wood suck it up into the pores. I let it dry for a week and then turned it. I think I'll try that with some more pieces. My other experiment was with this maple platter. I bored a hole with a Forstner bit in the blank. I stopped just above where the flat at the bottom of the platter would be. I filled the hole with blue dye. Let the dye soak in and let it dry. Then I turned and finished the platter.
Re: A little Box *LINK*
Eduardo Sarmiento Hall-Lima Peru
>Well done I love the shade and tell you it loooks the same an pink flame wood from Iquitos in the amazon (jim king place) check it out maybe you could copy some of the other colors as well no?
Exotics woods from peru
Re: A little Box
>Form is great. Finish is "hey wow man - do you see all of the colors? And the walls - they are moving!" The colors remind me of my much younger days. Quite unusual and striking.
Re: A little Box
Dave Fuqua
>That's a very cool effect. Any thoughts on using the same process, letting the dye soak in, and then adding a second color?
Dave
Re: A little Box
tek-Brunswick, Ohio
>That was my next idea. I'll soak the bottom of the blank in one color and let it dry. Then flip it over and soak the top in another color. Maybe I'll have blue on the bottom and red on top. Where the two meet I should bet purple. If I dont soak them too long I should still have some areas on wood that is not dyed. A little more controlled than the old tie dyed t-shirts I wore back in the 60's and earlie 70's.
