Red Palm help
Red Palm help
Red Palm help
Pete Kaup
>While at the Kansas City AAW conv. over last weekend I bought a RED PALM log, about 8" dia x 10" long.
My "wife" thought it would make a nice piece. She saw a finished bowl she liked.
Anybody have any experience with this stuff? Someone commented that it is real stringie. It doesn't appear to have a pith, at least not one that is visable. I am not a real experienced turner.
Would I do better in splitting it in half and doing two bowls or end grain and a taller vessel?
Any help would be appreciated.
Saw A LOT of Wood Central hats over the weekend.
thanks
Re: Red Palm help
Re: Red Palm help
John Trant (Baltimore/DC corridor)
>I have turn both red and black palm. It is very much like turning a bundle of weeds. Its arrangement of vessels is typical of monocots and provides none of the swirling grain of hardwoods. It is very soft with embedded hard needle-like fibers, it is easily torn, and tough to sand. If you oversand, the soft tissue is removed and the hard fibers lay proud of the surface. You need shrap tools, a light touch, and minimal sanding. I am not excited by bowls turn in the faceplate orientation however I love hollowforms and boxes turned in spindle orientation. Think of the striations as superfine zebrawood. Look at some of Bruce Hoovers work in palm for an idea of its beauty. By the way, use either a gouge or a sharp burr on a scraper to hollow out a box.
Palm is too porous to make a functional salad bowl but a decorative bowl holding dry material is fine.
My 2 cents,
John
Re: Red Palm help
Re: Red Palm help
JamieDonaldson
>Pete- I have turned a couple of pieces of unknown palm variety, and it was like celery. Many coats of lacquer base sanding sealer made it almost turnable, but I haven't been interested in trying any more!
Re: Red Palm help
Re: Red Palm help
Jim King
>I have never seen a palm with a solid core. Here they grow with a sponge like core that can be removed easily. I would be interested to know more about the piece you bought and what species it is. In line with the other comments it is a miserable wood to work with but can result in some stunning pieces if you live thru the barrage of spines being thrown out of the wood when turning. Here is a photo of a Black Palm log with the spongy center removed, the red palm here as well as the other palms grow the same.
Re: Red Palm help
Re: Red Palm help
Colin Spencer
>Pete
I have only turned small pieces of red & black Palm. These were for bottle stoppers. AS the other posts have stated it is quite hard to turn to a good finish but sharp tools and plenty of dust extraction are a must as the wood comes off as mainly as saw dust even with sharp tools. Sand all the way through the grits carefully and then it looks best with a high gloss finish. As to orientation I thing that two small end grain bowls or an end grain hollow form would show the features of the tube like grain of this type of wood best.
Colin
Re: Red Palm help
Re: Red Palm help
Russ Fairfield
>Nobody believes me, But....
You can soak the Palm in water, freeze it solid, and it turns like a dream. And, the shavings feel really good when it is hot in the shop.
Re: Red Palm help
Re: Red Palm help
Dave Fuqua
>Russ,
You mean the water doesn't expand and crack the piece when you freeze it? That seems kinda strange. Would that technique work for other types of stringy wood? I would like to try it for three reasons -- The first is it would be an excuse to acquire some palm wood. The second is that having a chunck of wood in the freezer would probably make my wife laugh hysterically (Honey it's in the freezer right next to the chunk of Red Palm would be amusing). The second is that it would be good to turn something cold as it is INCREDIBLY HOT & HUMID in Virginia right now.
Thanks for the tip,
Dave
David Fuqua
Sweating Profusely in Virginia
Re: Red Palm help
Re: Red Palm help-- kinda long
Wayne Allen - Carson City. Nevada
>Pete -- I just finished turning a piece of Mexican fan palm about the same size that you have. Ditto on all of comments about stringy and etc. I found that turning it end grain gives the best results. I roughed out the inside with a swept back gouge and the outside with a regular roughing gouge. The final cuts on the outside were with a 1 1/4" Lacer skew. The tearout was minimum on the outside, but it still needed something to dress up the piece since some of the fiber strands still kind of stand out. I figured rather than fight it I would kind of accent it and after smoothing it out with the skew, I put a wire brush to it at a slow rpm. The result was absolutly stunning. It got rid of the loose strings and brought out the fuzzy hairs of the fiber. Since the coloring is rather bland, I got the idea to dye it bright orange. It is very light wieght. All in all, it is a very nice piece. I would post a picture, but I don't know how to do it. --Wayne
Re: Red Palm help
Re: Red Palm help
Hawaii Turner
>Pete,
I have never turned Red Palm, but have turned quite a few Coconut tree bowls. This is similar to what Eduardo showed, except that the center is somewhat solid, on most trees. All of the characteristics of what the others posted persists in Coconot wood, especially the needle loke pokey shavings. I turn them end grain only. I will attempt to post a pic. Noth that this piece has cracks that I filled and laced with "butterflies" or as the Hawaiians called them "Peva". It isn't the most beautiful Coconut that I have turned, but above average.
Aloha
Doug
Re: Red Palm help
Re: Red Palm help
eaglesc
>WHen cut on the bias it makes an interesting pen.
I turned this a while ago and then told it was a difficult "wood" to turn especially the way I did it.
Not commercially stabilized butI kept the CA handy.
Very time consuming.
