Have a question? Ask Woody!
finish over foil
finish over foil
finish over foil
DWFII
>What kinds of finish is suitable for going over gold (or in this case, copper) foil? I have the proprietary "sealer" but the instructions for using the foil mention other varnishes. I'm partial to MinWax. Can I use that over the foil?
DW
In the High Desert of Central Oregon
Re: finish over foil
john Lucas
>I've used almost anything over copper and imitation gold leaf. Thke finishes I like best are shellac and lacquer. I've used polyeurethanes of different brands and tung oil and varnishes. They all seem to work but each will change the color slightly.
DWFII
>Thanks, John. that helps alot. The interior of my bowl is finished with MinWax Wipe-On Poly. I'd like to use the same thing over the foil so that any excess or "overage will just be poly on poly.
Someday I'm gonna get good enough to give back a portion of what you folks have given me...thanks again to all.
DW
