Filling voids
Filling voids
Filling voids
John in Abbotsford
>I'm rather new to turning, and have recently upgraded my lathe to a General 260-20 and am having a lot of fun turning some larger bowls now.
My question is in a number of the bowls there are voids that I wish to fill and I've read on this forum that if it is a large void that epoxy with coloured pigments and other fillers can be used.
What type of pigment is used for mixing into the epoxy? and also what are some of the other additives that are used to give the impression of stone etc. and where can I obtain these items?
Here are a few examples of some of my turnings.
I don't intend on filling voids in turnings such as these, but I do have some burl pieces that I'm working on at present that I think would benefit form filling the voids within.
T.I.A.
John
Re: Filling voids
Re: Filling voids
Bob Clancy
>My favorite for small to medium voids & cracks is ground malachite (get chunks from a mineral/rock shop and grind it yourself, it's pretty soft). Fill the crack with the finely powdered stone, flow in thin CA glue to get penetration, follow with medium glue which then gets drawn in and gives it body. If you start with medium, it may just sit on the surface and not penetrate. If necessary, sand or grind down to about the same level as the surface, then sand as normal. Malachite is relatively soft and sands well. Don't breathe the dust. It's a bit subtle, and I like it better than the more gaudy stones like turquoise.
Re: Filling voids
Re: Filling voids
john Lucas
>John I like filling voids with "Inlace". They also sell plastic chips that look like stone to mix in with the Inlace. It goes in well, turns and polishes well and looks great. It's a little expensive but I think it's worth it.
Re: Filling voids
Re: Filling voids
John in Abbotsford
>Thanks John
What I really would like to know is what can I use for colouring the epoxy, I know that powdered paint pigments will work also coffee grinds and toner ink, but are there other alternatives that are cheaper? will liquid paints?? "acrylics" "artists oils" etc mix effectively with the epoxy? I've thought of getting some cheap childrens water paints the little disks that come dry in a container and grinding them up, will that work.???
Re: Filling voids
Re: Filling voids *LINKS*
>I would not use oil based or acrylic paints or japan colors as colorants for epoxy. The oil or water based carrier can interfere with the mixing, curing, and final bond strength of the epoxy.
OTOH, just about any dry pigment, either tempera colors or the dry pigments (fresco colors) used to make oil paints, will work. When you consider the extremely small quantity of tempera you get in a kiddie water color paint box, and the difficulty in grinding it finely, you will realize that route is a false economy.
I have also used liquid dyes, specifically TransTint offered by Jeff Jewett, and sold at Woodcraft and many other woodworking supply stores.
Also, Lee Valley carries Earth Pigments, which can be mixed to closely match just about any wood color. I use the vegetable black, 53Z04.12, for filling voids in walnut burl. Others also recommend it for mesquite.
The difference between using a dye and a pigment is that a dye leaves the epoxy transparent, while a pigment makes an opaque patch.
Re: Filling voids
John in Abbotsford
>Thank you William
This is the kind of response that I was looking for, you've explained a whole lot in a few sentences. I'll have to pay a vist to Lee Valley since I don't have access to a WoodCraft store here in B.C.
John
