Anyone try this?
Anyone try this?
Anyone try this?
Rick in Colgate, Wi
>This may be dumbest idea that popped into my head lately but I have to ask.
Some people are boiling green bowls to eliminate water and reduce cracking. Has anyone tried boiling a green bowl in oil?
Lots of us have those big old turkey fryers that hold 5 gallons of oil and was wondering if maybe I can put it to some other use when it aint cookin' a turkey!
Just seems to me that with its higher boiling point, oil may work better to reduce moisture and at the same time put an oil finish to retard or eliminate cracking.
Re: Anyone try this?
Larry
>I would think that cooking oil would get rancid after a while.
Dave Fuqua
>Cooking oil or some of the oils used in finishing turning? I would think cooking oil might not smell so hot over time but who knows . . . maybe "Fried Bowls" would sell. I think some of the linseed oils, teak oils, etc., would be kinda dangerous to use for deep frying wood. Sounds sort of like an episode of Tool Time. . . .
Dave
Wayne Cooper Charlotte NC
>I am sure someone could give the 'flash point' of Boiled Linseed oil. I know peanut oil starts smoking at about 425 degrees. I think you should try it. Wayne
>Flash point of BLO is about 432 degrees F. Remember that there may be other additives (solvents) which have a lower flashpoint.
Mike in Fort Walton Beach, FL
>I'd have to say that I don't think it would be worth the risk. One of the biggest hazards frying turkeys is that if there is any moisture inside the body cavity of the turkey, the oil will "rupture" (for lack of a better term) and spill onto the flame (thus making a very large candle!!!). That's the big reason the turkey needs to be completely thawed. The reaction is very violent and I don't recommend this process to anyone. As far as the wood finish oils, apart from the reason above, the fumes are probably much worse than with cooking oil. Just my two cents but I really think that this idea is more dangerous than it is worth. Until then, happy turning!
tom libby
>I've been soaking some pieces in Linseed oil thinned with paint thinner, 3 to 1. Sometimes I forget and they stay soaking for a long time, so I've done no scientific study, but it seems to work most of the time. Ya, and time is the thing, but boiling oil sounds risky. The linsseed gives a real nice, natural color.
mick
>There is someone in NH who makes really incredible spoons and I saw him at a craft show (V. up-market) in NYC. He said he finished all his spoons by boiling them in a mixture of walnut oil and beeswax in a home type deep fryer. This is purely anecdotal. I think I still have his contact info if you like.
Mick, in The Bahamas
Eric
>Rick:
Maybe we can boil some bowls together sometime as we are practically neighbors. I use the DNA method and have been pleased.
JamieDonaldson
>I don't recommend this whacko idea, but if I were to try it I would use mineral oil. Much less volatile and about $12 a gal. when I buy it from my veterinarian!
