Trying a New Lathe
Trying a New Lathe
Trying a New Lathe
Bill Grumbine (Kutztown PA)
>Greetings all
Well, it doesn't exactly fall under John Lucas' title of weekend plans, but Friday SWMBO and I took a ride down to Baltimore to see John Trant and spend some time on his Vega 2400. John was gracious enough to give me free run of the shop Friday afternoon, and I arrived with a couple of "test pieces" of wood.
This whole thing arose from the thread I had started on the Jet 1642 vs Nova DVR lathe last week. Mark Kauder threw in a curve, and the next thing I knew, I was standing in John's shop in front of a lathe I had never seen before except for a few pictures. It was very impressive.
Here is a shot of the lathe after I had made a mess of the place throwing chips all over the room. It will probably never win a beauty contest, but what it lacks in looks, it more than makes up in power and performance. It boasts 26" of swing over the bed, 17" spindle capacity, a 2 HP 3 phase motor, and 500 lbs of steel and concrete to hold it on the floor. I did manage to get it rocking a time or two, but I was there to push it for all it was worth.
Here I am turning the "warmup" bowl, a small piece of curly maple that needed to be roughed before it turned into pen blanks and kindling wood. If you compare pictures, you can see that the tailstock is not in the way. It comes off (and goes back on) in a matter of seconds, allowing complete access to a bowl or hollow form.
Here is the "main event" bowl. This is another piece of curly maple from the same tree, but it is much larger, approximately 14" x 8" to start, and it was waaay out of balance. We started it out between centers, but I drilled the hole out a couple of times with the spur center and my 3/4" Glaser gouge, so we ended up grinding a flat and putting a faceplate on. I think I ended up with a better shape as a result.
Like I wrote above, I got it to rock a couple of times, and I squealed the belt, but what can I say? I'm just not used to those old fashioned belt drives anymore. :o Overall it did a great job, and I was very impressed, impressed enough that I will be on the phone with the folks at Vega Monday. Of course, I may have to sell a few more bowls first, but this lathe just made it into first place for that empty space in my shop.
Bill
Re: Trying a New Lathe
john Lucas
>Bill
I didn't turn on Mark's but I sure was impressed with the machine. As you know when you by a machine for $1800 to $2500 you don't get the best thing out there. The Nova, Powermatic, Jet and Vega all have little quirks but they will let you turn a lot of work. Glad you've found something you can live with. Or Teach with is probably a better choice of words.
Stuart Johnson
>Trying out a new lathe prior to making a purchase is sure the way to go. Did John have you autograph the lathe for him?
One thing, in the photos it shows the pulleys and belt open. Is that a cover sitting on the floor to the left? Every one has their own standards on what is safe and what isn't and uncovered pulleys have always made me uncomfortable.
Rod Peterson -- Ormond Beach
>I'm sure you're aware, but just in case someone else isn't, Mark did a review of his and it's in the Articles section of WC. Looks just like that one…
Empty space in your shop? Where?
Rod
>Hi guys
John, it does have a quirk or two, but the capacity to size ratio is amazing, and it meets or even exceeds some of the parameters I had established for a teaching machine.
Stuart, I did not autograph the lathe, but I did leave a mark on the wall where the big bowl hit after coming loose from between centers! Fortunately for me, it was not the first mark there. We did leave the pulley cover off, but mainly so I could see how things happened when there was a slippage of the belt, etc. No one got anywhere close to the belts while it was running.
Rod, I did read Mark's review when it first came out, and he put me in rememberance of it last week when he suggested I look at the machine. As far as spare room goes, I have two places I can put it, and with the tailstock off during down time, it will not interfere with walking about or sliding the Mini Max table back and forth. I may have to reduce my turning muscle to get around though!
Bill
Lee Dale
>Bill
Glad you had a good experience. I do all of my bowls on the Vega and do not need a ton of sand or rocks to keep it on the floor. If a person wants an exclusive bowl lathe, you get a lot of quality machine for your
money. Customer service ranks up there with the BEST. Welcome to the happy Vega owners fold....Lee
John Trant (Baltimore/DC corridor)
>Hi Bill,
I am glad you and the misses could stop by and chat for a while and I hope your drive back throught the evening traffic was not too troublesome. As most Ponders and WC'ers know, Bill is the consummate host, but I had the distinct pleasure to learn that he is even a more gracious guest. He brought me a beautiful piece of maple burl as a "thank you" gift. Too kind, in deed.
We had fun testing the Vega lathe. I had turned an out-of-balanced cherry bowl blank of 24" but I pretty much babied it along. Bill, on the other hand, took an 18+" blank, put it between centers in the most awkward angle to produce the most out-of-balance situation, and then had at it. This was a good experiment for me in that I could concentrate on the behavior of the lathe and evaluate problems/potential improvements. Even though most things I turn are not grossly out of balance, I am convinced more than ever that widening the footprint (towards the back of the lathe) will be helpful.
And yes Stuart, I always keep the cover on the pulley assembly. In fact, I rarely change speeds since the "high speed" arrangement provides enough power at the slower rpms for all but the largest blanks.
Again, thanks for the visit and you are welcome anytime. In fact, if anyone in the Baltimore/Washington DC area wishes to give it a whirl, please just let me know.
John
