Conquered the Pear
Carole in VA
>Finally conquered the Pear I was trying to dry without huge cracks. I boiled this piece for 1.5 hours then soaked in DNA. Problem solved.
Conquered the Pear
Carole in VA
Dark Spots: Is that the wood or bark inclusions?
steve antonucci
>Hard to tell from the picture? Looks like a nice shape.
Steve
Re: Dark Spots: Is that the wood or bark inclusion
Carole in VA
>Thanks. It's bark inclusions.
Re: Pruning limbs scars.
Keith Newton
>It appears to me that the dark areas are where two limbs were trimmed from the trunk. The little dark lines pointing down as you view them is where the scar-tissue healed from each side as it comes together to cover the wound, a little bark is captured between before it totally closes over.
The darkness is due to the minerals in the sap oxidizing while the raw wood is exposed to the elements / air, before the scar heals.
In the top photo, the camera is looking down the tree. The base, or ground would be away from the viewer.
That is my read anyway.
Can you share any details with me?
Dave Smith, Longview, WA
>Hi Carol,
Pear can be a real problem. A combination of boiling and soaking should help with any problem wood. I recently had problems with madrona that I soaked for 24 hours before drying. I soaked an other batch for 4 days and set them a side to dry while I went to Kansas City. The pieces appear to be dry with very few problems.
This is the first wood that I have intentionally extended the soaking time to improve the results. I sold, traded, and, finally, gave away a lot of madrona at the AAW symposium. If the people listened to my advise about boiling or extended soaking in alcohol they have a chance of some nice finished turned pieces. If they didn't hear what I was saying, they will have some nice fire wood. DAMHIKT
Thanks for the update on the pear.
Dave Smith
Oz was great but there is no place like home in Longview, WA.
Re: Can you share any details with me?
Carole in VA
>Hi Dave,
I should have kept records, but I didn't. The first piece of pear I only soaked in DNA overnight (about 7 hours) and it cracked horribly when it dried even though it did not have the knots/inclusions that this piece has. Then I read something about boiling doing something to the sugars in fruitwoods (don't ask me what...I'm senile!) so I decided to try that and then speed up the drying process with alcohol soak. Seemed to work. I also used this process on some cherry and got no cracking.
