Alcohol & food.
Alcohol & food.
Alcohol & food.
Bill MacLachlan
>Hi guys; I have had some requests to make some salad bowls. Some will be wedding gifts and will be required soon. Some fresh willow was delivered Saturday and it should be large enough to handle some nice bowls. But if I try the alcohol soak method, will it be safe for food afterwards? I checked the archives and cannot find where this has been discussed before. I assume it should be all evaporated out or else the finishes would not adhere properly.
Thanks, Bill
Re: Alcohol & food.
Re: Alcohol & food.
Carles
>No problem if you use ethylic alcohol. Methylic is toxic and very dangerous. Denatured alcohol is basically ethylic alcohol and it is food safe when it should be evaporated.
Hope this help.
Un saludo,
Carles.
Re: Alcohol & food.
Re: Alcohol & food.
>Not a problem no matter which "lower" alcohol you use (methanol, ethanol or even isopropanol). By the time the water is gone, the alcohol is gone. Monitor the weight. When it's stable - no more alcohol or water.
