buffing hi-gloss urethane
ken chase
>I plan to let the high gloss urethane dry about five weeks.
Then I want to buff. Should I use all three steps in the beall
system or just the white diamond? Is this a good idea?
Thanks
Re: buffing hi-gloss urethane
>Ken
It depends on how well the finish goes down. There are two ways I see the Buffing being used. You put down a finish and then polish the finish using one or all of the grits. This simply polishes the finish and leaves bumps and ridges that existed in the finish they are just rounded over and polished to a high gloss. In this instance you can easily skip the tripoli.
OK I lied there are 3 but I'll get to that. Another method is to put down layers of finish and sand each layer until you get a flat perfectly smooth finish without any imperfections, ridges, pores, etc. Usually on this finish you start with the tripoli to get rid of the sanding marks and then go on to the white diamond.
Another method and probably not the last is to put down a penetrating finish such as an boiled linsead oil. This finish is then buffed. I would usually start with the tripoli and go up unless it's a white porous wood, then skip the tripoli, or a dark porous wood in which case I would skip the white diamond. The wax will fill the pores and nothing looks worse than walnut buffed with white diamond, unless you fill in the pores first.
To answer your question, I think if you put on several layers of Poly, then you have probably filled the pores enough to not worry about which compound to use. I would start with the tripoli and go on up. You are right in waiting to buff. When I hand polish furniture using poly I wait at least a week. You will also find that if you use a slow speed you will be less likely to melt the finish and cause problems.
Hope others chime in on this, I'm not an expert finisher, I simply have my methods that work for me.
Ron In Drums PA
>I mosty sand between each coat with either 1000 or 2000. Then just buff with white diamond. I usally don't wax
