Refurbished DVR??
Refurbished DVR??
Refurbished DVR??
Dave in PA
>Anyone have any experience purchasing a refurbished DVR? Problems? Anything to watch out for?
Dave
Re: Refurbished DVR??
Carole in VA
>Dick Parr over on SMC just got one. He's pretty happy with it.
Dick Parr
>Dave,
If you are talking about the ones from Tim, the Teknatool USA rep I have had no problems and am really enjoying it. If he hadn't told me was not new I could not tell by looking at it.
I am very satisfied with it and the service.
Dick in Knoxville
Where is Tim ? Thanks ! .
Fred in NC
Re: Where is Tim ? Thanks ! .
Dick Parr
>His name is;
Tim Geist (T V Geist MG INC)
225 Neale Rd.
Parkersburg WV 26105
1-304-295-8166
He is a really fine person to deal with.
Good Luck
Dick in Knoxville
Stuart Johnson
>The DVR has only been out 2 or 3 years so what type of refurbishing is being done? It seems like they should all be too new to require anything unless they were totally abused.
Brian Gray in Sandusky, OH
>I own one, and it's a fantastic lathe.
The reason that there are so many out available as refurbished is that they updated the software that controls the computer. Originally, the lathe had software that would always reset the RPM's to 1500 if the lathe is ever switched off. So if you were turning a large piece at low RPM's, and switched the machine off, you will reset to 1500 rpms when the machine turns back on. This could be dangerous, if you forget.
So a while back, Woodcraft sold a ton, and had a no-questions-asked return policy. A lot of people found out about the software update, took advantage of Woodcraft, and returned their lathes to get new ones with the new software, which remain at the original rpms, rather than reset rpms to 1500 when switched off.
I got mine for around $1,000. The only thing that I have to do is remember that if I switch the lathe off, when I turn it back on, it will always revert to 1500 rpm...no biggie for me, and I got a heck of a deal.
Refurbished DVR?? Thanks
Stuart Johnson
>Brian,
Thanks for the reason for the number of refurbished DVRs. The DVR has received such high marks I couldn't understand why there would be such a large number. Seems like a software upgrade would have been a lot more cost effective.
Re: Refurbished DVR?? Thanks
Dick Parr
>The one I received is a new one (well 3 months old) with the software upgrade. But it appears the owner forgot to tighten the set-screw on the chuck insert to the spindle and turned the lathe on in reverse. When the person did that the insert/chuck spun until the set-screw got caught on the threads. In doing so it messed up about 1" of thread on the spindle. The lathe was returned.
Once it was received in for repair all that had to be done was chase the threads to clean them up and everything else is fine with the lathe. But it could not be re-sold as new, so I got it as refurbished.
The little bit of messed up threads does not bother me and the insert and chuck seat as they should.
I love the lathe.
Dick in Knoxville
Eric
>Are these refurbished units still available from the contact above? is the price about $1000? If so, this might make my new lathe choice much simpler...
