Sanding - finishing inside a bracelet
Fred in NC
>OK, one dangerous contraption right out of my secret machine shop ...
I have made a few bracelets. I have hole saws to cut 2-1/2" to 3" holes in a square piece. Then I cut the corners off in the bandsaw. To turn the outside I mount the piece on a mandrel. I turned the mandrels out of construction grade pine, about 3-1/2 square by 5". In one end I drilled a 7/8" hole, and used a tap to thread to 1"-8 to fit my spindle.
With the mandrel blank on the spindle, and the live center on the other end, I just turned to a good sliding fit for each size bracelet. Then (off the lathe) I made two crossed cuts from the tailstock end for about 2-1/2". This is the same idea as a collet. The tailstock will expand the mandrel slightly to hold the bracelet in place.
Finishing the inside was a brain teaser. I wanted to round the inside of the bracelet slightly to make it more comfortable. I do not have any suitable chuck jaws, so.... the result can be seen below. The reason for the wood is twofold: It can be adjusted to the shape of different bracelets, and the wood parts are easily replaceable.
NOTE: I do not get my fingers near that spinning nightmare. A piece of sanding sponge is attached to a stick, just like a turning tool.
