Questions re: Powermatic 90
>Hi, all. I've just committed to picking up a Powermatic 90 and am wondering if any of you would care to comment regarding its strengths/weaknesses, etc. I'm assuming bearings & pulleys will all need to be inspected.
I'll be installing it in my garage/shop and would also appreciate any tips so far as clearances, etc. If possible I'd like to put it against a wall but don't know if I'd lose any functionality by not being able to get around to the backside of the lathe.
I've never turned on a wood lathe but have a number of years experience on metal lathes. TIA!
Re: Questions re: Powermatic 90
The 90 is a "Hoss"
Terry Daniel
>The PM90 for years was the best lathe you could buy but it was/is a spindle lathe. It will turn bowls up to 12" diameter but the lowest speed is too fast for out of balnace blanks. You can slow it down with a lower rpm motor, a variable speed motor, or a jackshaft. The toolrest will not go low enough but you'll get used to that. If you plan to turn spindles it is a fine lathe as is. The bearings are probably good because that old beast is almost indestructible. 3 ft of clearance to the wall would be best as anything coming off the lathe and hitting the wall is going to bounce back into your face.
TD
Re: The 90 is a "Hoss"
>I understand it weighs about 600 lbs. I haven't turned a bowl yet but I've purchased and watched (3 times ;>) )Bill Grumbine's tape and am champing at the bit, so to speak. If I cut a blank relatively round with a bandsaw will the lowest speed (100 rpm I think) still be too fast? I'll be screwing it to the face plate and bringing up the tail stock to secure it.
Keith Tompkins
Keith Tompkins
>Hi Frank, I've turned on these lathes also...a big, strong piece of cast iron. A machine shop can make a set of riser blocks to increase the swing to 20". Before I got a lathe with variable speed, I would balance a blank between centers. If unbalanced, the heavy side will rotate to the bottom. If the lathe is three phase, you may be able to wire it with speed control.
