Treadle power
Treadle power
Treadle power
Phil Joines Krum, Tx
>Has anyone ever used a sewing machine treadle to power a mini lathe? We have an old style (black) CarbaTech that I'm thinking of using.
Re: Treadle power
Re: Treadle power
Fred in NC
>I have not, but have been looking all over for an old threadle base. The sewing machine flywheel is quite big, so the angle of the belt where it has to enter the lathe headstock from the bottom might be a problem. Might need a couple idler pulleys.
Since it looks like I will not find one very easily, I have been thinking how to make my own. The flywheel is the biggest item here.
What I have in mind is a human powered lathe for turning pens at demos.
Re: Treadle power
Keith Tompkins
Re: Treadle power
Keith Tompkins
>Hi Guys, Ihave considered a treadle machine also....I think it would draw a lot of attention at a craft show, etc..
A laminated plywood disc may be glued up, and trued on the lathe. An old auto flywheel may be bolted to it for extra weight...it's pre-threaded. Sounds like a fun project!
Re: Treadle power
Re: Treadle power
RevDoug
>I believe that the issue of the flywheel size will take care of itself. Unless you build a left handed lathe, the head stock of the lathe is on the left. The flywheel of the sewing machine treadle is on the right side. Therefore, a transfer shaft will have to be fabricated to transfer the power from the right side to the left side. I've been thinking about a treadle pen lathe as well. Turning pens on a mini in front of folks is a great sales tool. Turning them on a treadle should boost what ever it is that folks are thinking and help sales even more.
Turn 'em round,
Re: Treadle power
Re: Treadle power
>The bases in the antique stores close to Dallas go for $80-90. We found a complete machine at a place about 100 miles out for $25 (not a Singer). The cabinet is in sad shape but I think it's restoreable. The drawers would make a good place to keep all the small parts.
The lathe is longer and narrower than the hole for the original machine and the headstock is on the opposite side from the flywheel so it will get a jackshaft under a new top.
Re: Treadle power
Re: Treadle power
>A flywheel from a trashed air compressor would work and may look more interesting painted up.
Re: Treadle power
New turning position?
Fred in NC
>I guess you will be sitting down while turning !!
