Metal Rethreading Question
Clem Wixted
>I would like to know if a 1-1/4" x 8 TPI (female) to 33mm x 3.5mm (male) spindle adapter can be rethreaded on the 33mm male threads to 1 X 8 inch?
Is there enough metal on the 33mm threaded male end to allow it to be reduced and threaded to 1 inch by 8 threads to use on my wood lathe?
Thanks,
Clem
Re: Metal Rethreading Question
Fred in NC
>Clem, to determine if there is enough metal for rethreading, use a caliper and measure the inside diameter of the threaded part. It needs to be 1" or so.
I do some work with metal. I am not sure if I would attempt rethreading the adaptor. You need a machinist with a good metal lathe, and that can be expensive, unless you have a machinist friend.
Besides, I am not sure you can get a perfect threading job. The concentricity has to be between the internal and external threads. Just chucking the adpator by the unthreaded part will not guarantee that. You might end up with a very wobbly setup.
In your case, I would buy a new adaptor, and try to sell the old one.
Good Points
Clem Wixted
>Fred,
I thought of e-mailing you directly because I knew that you would have some good input, but I couldn't find your e-mail address.
Thanks for the information. Back to the drawing board :-)
Clem
