Any power transmission experts out there?
Pete in Holland, MI
>Fellow lathe owners:
As an owner of a JET 1236 lathe, I am becoming aware of its long and short comings. Turning a lot of larger diameter bowls recently, I am experiencing slippage of the belt while turning larger diameters (admittingly taking heavy cuts). Notes posted in the past lead me to replacing the belt with a new one from the NAPA store with a certain part number. This basically gave me a similar belt to the one removed from the machine. Performance did improve, a little. The belt is described as a "wrapped" belt, where the sheets of fabric from which the belt is built up from, are wrapped & formed to create the belt.
I have seen Reeves or simialr drive installed in snowmobiles, metal lathes, drill presses and conveyor speed controls. None of these machines had a "wrapped" belt, as the JET machine, but rather a "cut" belt, where the V-sides of the belt are cut to expose the raw rubber, and sometimes the inner face of the belt is cut/molded to resemble a cog belt. Would stand to reason that that belt would offer more grip to the "hyphenated" pulley faces of the Reeves drives.
The wrapped belt is cheap, and has a wrapping seam on the belt, which will cause a slight "bump" on belt drive machines each revolution of the belt over a pulley.
Wouldn't it make sense to get a "cut" belt for our Reeves drive to better power our work pieces ?
Thoughts / expierences?
Thanx.....
Pete
Re: Any power transmission experts out there?
Gary Evans, Tallassee, TN
>Hi Pete,
For what it's worth, I understand that the link belt sold by WoodCraft and others gives a performance increase on a Reeves drive, as well as providing quieter operation. I have a Delta 45-700 with the Reeves drive and thought about trying this upgrade, but never got around to it.
I resolved my problems with the Reeves drive by buying a 20" WoodFast. 8^}
Gary
Bill Crommett
>Pete:
If it is belt slipage that concerns you mostly, get a can of "belt stick" which is available at better hardware stores and maybe at sawmill supply locations. The only sawmill supply outfit that I know of in Michigan is at Flinttheremust be a dozen others.
RevDoug
>You can get a similar product at most automotive supply stores like AutoZone or NAPA.
Turn 'em round,
