Non laser technique for bottom HF vessels
Donna Banfield
>Steve, if you're only trying to get a measurement on the bottom of the hollow form, this low tech tool might work. I cannot claim this, and I'm sure others use this, but it came with the lathe when I bought it from the original owner. He was doing deep hollow forms with the Dennis Stewart Arm Brace.
Using a long piece of metal rod, aluminum, steel, whatever is thin but won't flex, afix a long piece of 1/2" by 1/2" thin wood, by drilling a hole in the center of the wood. You're essentially making a 'T' or cross. The hole that you drill should be large enough to allow this wood cross piece to slide easily up and down the metal rod.
Use wing nuts on either side of the wood, but slipped onto the rod to keep the wood 'T' in place once you get it to the position that you want it to stay.
_________|___________ Wood
| Metal Rod
To measure place the rod into the hollow form until the tip hits the bottom of the form. Then slide the wood up until it rests on the opening of your hollow form. Then use a large square edge to place on the outside of your hollow form at the base. Then pull the metal rod out of the form, and place it perpendicular to the hollow form, just like it was before, only this time the rod is OUTSIDE the form. By comparing where the end of the rod is to the square edge, you can see how much or how little room you have left at the bottom of your vessel.
I wish I could post a photo of the tool, and how to use it, but for the life of me, I cannot seem to get the sizing right to post anything here on Woodcentral. I've been able to successfully post to WoW, but not here! And that's after help from Woodcentral members. If you'd like, I can send it to you directly if you send me an email telling me it's o.k. Or I can post to WoW.
Donna
