Cherry- attempt at carving
steve antonucci
>I've always like John Jordan's carved vessels, and here's a rather so so attempt at the style. probably spend some more time with the carving someday...
steve antonucci
Re: Cherry- attempt at carving
Ruth Niles
>Steve,
It looks great to me. I also love John Jordan's work and I think you did a very nice job. Was it difficult or take a lot of time? I've been wanting to try a little carving myself.
Ruth
Hard, no. Actually, it was easy, but...
steve antonucci
>I'm not sure about the look. I used a small ball mill on my Dremel, and it's a little "fuzzy" for my taste. Only took a few minutes, but I'm debating going bacck over it with a V carving tool. A little deeped carving, cleaner lines...
Steve
Ed Kelle
>Nice work, do you have another pic of the profile view of it? You can try a nice V chisel or one of those tiny v shaped diamond tipped bits in the Dremel. I had gottn a pack of 10 for about $15, its not as sharp as the chisel but it will make a sharper cut than the round ball.
One thing I have been using is a power carver, it takes chisle blades and does not move the blade until if feels pressure against it. Makes nice clean cuts and with a lot less effort that chiseling by hand. I'm going to post a pic of a bowl I used mine on.
I hope you post pics of all your works after you put the finish on, they are really going to pop then. For me, that is the real fun part, waching it come to life when I put oil on them.
Keep up the good work!
Another view...
steve antonucci
>I had a small V tool that I started with, but it's very hard to use. I tried the dremel V, but I can't keep it "running straight" and the small tip wants to wander.
One day, when I feel like doing something, but not too much, I'll probably sit with a a V tool and recarve the top. Then the finsh will really shine, but the top is a little muddy right now.
Here it is from the side view:
