3rd textured cherry bowl
Ed Kelle
>This one is different, I textured the top with a sanding wheel in the Dremel, one of those very thin ones held at 90° to the surface. I wrapped masking tape around the bottom of my cut line, went around 4x. Trying to protect the smooth parts a bit. Worked pretty well, not a distinct breakline, which is what I initially wanted, but led to a softer runoff which worked well. Some lines I burned with the wheel on purpose, Not as prominent after I added the stain. On the inside I tried adding some red fading away from center, by using thinned oil paint, but this came off when I applied the finish, except for a few areas of grain where it remained.
Any suggestions for applying a fading color in the future? I was thinking of water based dye but did not want to raise the grain with it. anyone spray alcohol based dyes? I see where Craft supplies is having a sale on Spirit based dye but have no experience with that at all. Whatever I use, I hope to airbrush it on to get a soft effect.
The rim of this reminds me of palm. I plan to explore this more.
Re: 3rd textured cherry bowl
>Ed
Great job on all 3 bowls. I think I like the ball texture on the second bowl the best. I spray analine dye using an airbrush if If I want to fade. I don't worrry about raised grain. I raise it before I spray. I have also taken oil based stain and mixed several together to get the color I want and wipe it on. Then go back and rub it with thinner to take away color or make it fade a little. Most dyes will dilute the same way. With water based dye which is what I use most you simply wet a rag and rub on the areas you want to lighten. Some woods work better than other for this. I guess it has to do with the penetration of the dye.
>I really like that. The texture work looks great!
Tommy
>Looks good. I have used a couple of the dyes dissolved in alcohol. You can wipe off some of the dye with a rag or wipe dampened with alcohol. You can blend it in or "fade" it across an area. I've also done a color transition from one area to another. I've done that with flat stuff, not turnings.
Ed Kelle
>Thank you John. I just got some aniline dye from a friend and will be doing a bit of experimenting. Tonight I mixed up some with DNA as an alcohol based test and I will try some with water base as well. I have lots of scraps to test with. I want to adapt some traditional airbrush masking methods to my turnings.
Ed Kelle
>Thanks, it sure is fun trying new things. I hope to have more soon
Ed Kelle
>Thanks, I borrowed some aniline dyes today and mixed them up with DNA. I'm going to be doing a few tests tomorrow, mostly on flat scraps but that should be enough to find out what works best for me.
Steven Antonucci
My favorite of the three...
steve antonucci
