Veritas - Innovation in Tools
Teco FM100 question
Teco FM100 question
Teco FM100 question
kwgeorge
>Well when I got home today I received a very pleasant surprise. My new 3-Phase motor and controller had arrived. Unfortunately I will get to play with it very little for almost two weeks as I don’t have much time in the evening and I leave on a week long business trip Sunday. It is still exciting though and I am looking forward to installing everything.
The controller is a Teco-Westinghouse Fluxmaster 100 and as I sit here and read the manual for it I realize that there is a ton of things this thing can do. I am wondering if anyone here has any experience with this particular controller and can perhaps pass on some words of wisdom and advice on the installation and setup.
Any thoughts would be appreciated.
Thanks
Kenneth
Re: Teco FM100 question
Stuart Johnson
>Kenneth,
What motor did you get? I've been toying with the idea of buying one for my Nova3K. Just for grins I pulled up a copy of the manual for the Teco and was lost after the first 6 pages of warnings. Two that caught my attention were the do not use in a dusty area, and do not use around flamable stuff. I would think a lathe would qualify for both of them. Do you have any concerns?
Please post how you find hooking it up goes and does the manual make it sound my complicated than it is.
>George
I think that is the brand that I put on my Nova 3000. I don't remember for sure I sold it about 15 months ago. Those things can do almost anything. You actually only need to figure out 3 things. How to hook up the AC. How to hook up a remote switch, mine had a 24 volt set of contacts for the switch. And how to adjust the electronic braking. The braking is just a matter of figuring out how to set the program codes to speed up or slow down the braking. Without seeing the manual I won't be able to remember how to do it but I'm not computer literate at all and figured it out. There's also an audible frequency adjustment. Mine made a high pitched whine but I remembered seeing something about that in the adjustments so I went in and reprogrammed that setting and the whine went away.
kwgeorge
>Stuart, this is my third conversion to electronic variable speed on a piece of equipment. It is my second for a wood lathe. On the first lathe I used a DC motor and was not very happy with the low end power so I thought with this one I would go 3 phase with a controller. Mostly due to a thread here awhile back. I am also installing this on a Nova 3K but I decided on just the 1hp since I rarely do anything big enough to justify more.
John, I have the wiring hook up figured and I don’t have the remote keypad accessory but you have me wondering about the breaking. I was concentrating on sections such as the “Drive Capacity” and setting the 7 programs for preset speeds so I could quick select through them. In braking there are two sections, the first is “Stoping and Braking Resistor Protection” which is currently at a factory default of “Decel to Stop”. The next section is “Dynamic Braking and Priority of Stopping and Speed Search & AVR Control” this has the following selections;
xxx0 : Enhanced Braking Capacity
xxx1 : Standard Braking Capacity
xx0x : STOP Key effective in Remote Control Mode
xx1x : STOP Key ineffective in Remote Control Mode
x0xx : Speed Search controlled by Terminals on TM2
x1xx : Speed Search effective during Inverter Start
0xxx : AVR Function effective
1xxx : AVR Function ineffective
0000 is the factory default and I am a bit confused on these settings so anything you could jog from you memory would be great.
Steve Mushinski
>George,
The braking you are talking about needs the external resistor to function. If you didn't buy the resistor then just leave it on the factory defaults and away you go. About the speed settings, why would you want to have presets. With the variable speed just turn the pot to where you want it each time you start the lathe. Bigger off center you start slow and increase the speed as wood removeal will allow. The little pot on the front of the controller works well. For a few extra greens you can buy the remote which I do recommend. I made mine but the one you buy is just the cable and you take the front panel off and mount it in the box at the end of the cable I am told. Very easy and looks good too. Any question about some of the settings email me and I will try and help you out.
>George
Yours has more options than mine did. I was confused by all the different terminology that sounded something like braking. I think the dynamic braking was what I played with. The good thing is you can reset anything you do so no harm is done. Try it without adjustments first. The one we installed on my friends lathe worked great right out of the box.
Mine didn't have a remote key pad. What I did was wire a switch to the forward or reverse terminals on the main board. It was really easy and quite clear on the wiring diagram. They used jumper wires and I just removed them and put in a switch. There was also a place on that board that you could wire in a remote speed control. I put the switch and potentiometer in a box with a 6 foot cord for remote control.
Bruce Wiseman
>HI,
When you get back from your trip and get a second, would you email me with the part numbers and where you got the motor and controller, I am looking to do exactly the same thing. Everytime I read the various discriptions and requirements of 3 phase or dc motors my eyes glass over and my brain fades away. (I think "they" warned me about that back in the late sixties but I didn't listen..better living through chemistry.)
Thanks,
Bruce
Re: Teco FM100 question *LINK*
kwgeorge
>Let me tell you, I got this place from referrals in different threads I have been reading over the past 6 months. I am very pleased with them indeed and buying here sure beats the eBay hassle! Just don’t depend on them answering email as they have still never answered mine but on the phone they are great. Got my stuff in 5 days including the weekend and everything was Brand New product with the manual.
I bought the internet special.
Dealers Industrial
