Tennon warped????
DougJ in Crawfordsville, IN
>I have a smaller cherry bowl roughed out and alky dried. The problem is there was quite a bit of warpage in this bowl. Even the tennon warped, it is now oblonged shaped. What are my options?
Thanks
Tennon warped????
Thanks
Re: Tennon warped????
Mike Schwing from Md.
>Doug, if you have enough tenon there, you can true it back up on the lathe and still use the same jaws. Mount it with a compression chuck and use the tailstock point to center it with the center point you hopefully have on your tenon. Spin it up and true the tenon.
If not enough left, you can still use it. True the tenon as above, then make a glue block that will fit over the tenon in mating fashion. Make the glue block by first creating a tenon on it between centers. Then stick it in the chuck, and now shape it to custom fit your tenon on the bowl. Epoxy it on and you should have a well centered bowl to work with and plenty of hold power.
There are other methods but one of these two should work.
Thanks Mike
>I appreciate the advise.
A side note,, sure miss seeing you on the other board, WWF.
tek-Brunswick, Ohio
>“I have a smaller cherry bowl roughed out and alky dried. The problem is there was quite a bit of warpage in this bowl. Even the tennon warped, it is now oblonged shaped. What are my options?
Thanks”
If you have left enough wood you can turn it round. You can true up the tenon by putting the bowl on a jamb chuck. The simplest way is to put the inside of the bowl over your scroll chuck. Bring the tailstock up to the center of the tenon and apply enough pressure to hold it in place. It helps if you mark the center of the tenon before drying, it makes it easier to find. The chuck is just driving the wood by friction; it is not tightened on anything. When you true up the tenon make sure you true up the shoulder also. After the tenon is trued up back off the tailstock and move it out of the way. Chuck the bowl up by the tenon and have fun! Some turners don’t true up the tenon. They just find the most secure and true orientation of the wrped tenon in the chuck. I’ve never done it that way though. I hope this helps. That much warping is not uncommon, especially in fruit woods.
scott hogsten
>Mike's got it right - I would strongly reccomend using a glue block especially on a smaller bowl. It takes a little longer because you have to wait for the glue to dry but the advantage is that you can finish all but the bottom of the foot of the bowl while it's attached to the glue block. Gripping by the tenon leaves that annoying area where the jaws grip and you can't get the gouge in there to clean it up. Then you have to spend time reverse chucking and hoping that everything lines up so that you can turn that last little bit of the outside of the bowl.
Scott
like Tek said, why retrue the tenon?
steve antonucci
>I have this all of the time, and it's no big deal. Just grab the oval tenon, and retrue the bowl. Once the bowl is trued, I use cole jaws to remove the old tenon and finish the bottom. My experience is that this works 100%, and avoids the unnecessary extra step (since once you true the tenon, the bowl won't be true to it anyway...)
Steve
we have vastly different experience
>You're probably better at it than me, but a big bowl that is not securely held by a trued up shoulder and tenon will undoubtedly wobble off balance or come completely out for me. I find a small one is not nearly as likely to suffer the same fate.
For What It's Worth...
Barbara Gill, Remlik VA
>When I rough turn a bowl I make sure there is a dimple both in the center of the tennon and in the center of the inside of the bowl. Usually if I use my drive center and the tailstock I can true the tennon with those centers. At least it gives me a two points of reference if I need to make adjustments after lightly holding between the drive and the tailstock.
woodspinner/ Bill Hale
>If you start between centers you always have a true center on the tennon. If you oversize the tennon as you do the thickness of the bowl for drying you will have enough to retrue the tennon.
If not just put it in the jaws as straight as you can and finish it.
Good turning and be safe
Bill in Casa Grande, AZ. HOT HOT HOT
Nah, I've had a few come loose...
steve antonucci
>You're right. On most of the "smaller" bowls (<10"), I can usually grip them pretty good. Since I've started alcohol drying (works for me), I've seen a huge reduction in how much the bowls warp. I've been returning at ~1000 RPM, and I take a pretty light cut until things are round inside and out.
On large bowl, I slow down a bunch (700 RPM) and take an even lighter cut. I've recut a 15"x 6" bowl, that may have shaken loose once, but didn't come off.
In my experience, if I ask 5 people how to do something, I'll get 6 answers. Some are better than others, and it always depends.
So don't sue me if Mike is right and you get hit with a bowl.
Steve
Thanks
>Some very good and forgotten advise. I usually (in fact have never) don't true up the tennon. I think now I will start to add this to my procedure.
Thanks to all for the help
