To Fill Or Not To Fill
Duane Hill
>I recently started a hollow form piece that had some bark inclusions on it. As I rounded the piece (approx. 8" diameter and 3" thick), I noticed that one of the bark inclusions appeared to run from the top of the piece, down the side and across part of the bottom. There was a lot of bark and dirt in this inclusion. I cleaned it out with my Dremmel and noticed that the inclusion is prety deep. Two questions really. First, as I get ready to hollow, should I fill this inclusion with an expanding glue like Gorilla Glue to stabilize the piece for hollowing? Second question, after hollowing, should I plan on filling the inclusion with something (stones, etc) or leave it as a void? I'm curious to get some other opinions. Thanks
Re: To Fill Or Not To Fill
Terry Daniel
>Duane, it is difficult to answer your question without seeing the piece but if the inclusion splits the piece I would "stitch it" using a mix of epoxy and soot and sawdust. With this mix you can build bridges to connect the halves or you can fill the entire void. Or depending on the color of the wood you could fill it with turquoise or brass filings insted of the sawdust and soot. There are many other ways to deal with it too.
TD
Norm Smith
>Hi Duane,
What I would do is.
If you want to fill the piece and have the outside of the shaped close to what you want you should fill the void with epoxy and stone or whatever prior to hollowing. If the voids are deep you can take up some of that inside space by filling it with a cheaper substance (shavings and glue). If you want to leave the voids open, just wrap the piece in duct tape and than hollow.
It works for me.
Good luck,
Norm
Duane Hill
>Thanks Terry. I think I know what you are talking about with "stitching", but could you elaborate a little more.
Duane Hill
>Thanks Norm. A couple of good ideas there.
Paul in Phoenix, AZ
>Duane,
Used, dried coffee grounds and CA would work as well. Just stand back when you add the CA because it's self accelerating. It will leave little pits that can be filled with ebony dust or wood dust of a different color than the coffee. It will look like a bark inclusion.
Sean Troy
>Hi Duane, You might try finishing the outside to final sanding and then wrap the piece tightly with blue tape. Finish hollowing .Let us know how it turns out what ever you do.Sean
>I would wrap it with nylon strapping tape. Blue tape does work but it's pretty fragile and if it gives it gives quickly. Nylon straping tape doesn't have any stretch at all and won't break unless you cut it.
Re: To Fill Or Not To Fill *LINK*
Terry Daniel
>If you want to leave the area of the inclusions somewhat open then just make a few bridges or stitches to span the gaps; this will hold the piece together while letting the inclusions appear to separate the piece. Look at my website at the oak burl with inclusions that I did this way. The burl was divided into 4 parts by inclusions but by bridging it I was able to turn it. The piece sold for $2000.
http://www.theoldrebelworkshop.org
Dick Hines
Dick Hines
>You want to give some thought to how you are going to hold it together while you are hollowing.
Here is what I do. I wrap the piece in masking tape. A couple layers usely does it. You can also use the tape that U-Haul sells to wrap tools when you are moving. It stickes to it's self.
woodspinner/ Bill Hale
>Duane
Be very careful on this. I had a piece as yours is with bark. I thought that I had secured the sides. As I was doing the final rough on the outside it became airbourn in two pieces. I had errored in my judgement of the depth of the bark and as the sides came in I cut away the final attachment. My glue had not made full penetration.
Good turning and be safe
Bill in Casa Grande, AZ.
