New WoodChat!
Dyes and Buffing
Dyes and Buffing
Dyes and Buffing
Chris Andrew
>I have some pieces that have been colored with aniline dyes then given a couple coats of Danish Oil finish. I would like to buff them using the Beal system but am fairly certain I'll pick up the dye on the buffing wheels even though I've put on Danish Oil. In the past I have built up a lacquer coat and buffed that out, but don't want to do that on these pieces. Can anyone recommend a way to seal the finish/dye so I can buff without turning my buffing wheels pretty colors?
Re: Dyes and Buffing
lots more oil
Terry Daniel
Carole in VA
>Chris, I have a piece with Prismacolor that I want to buff, but I am doing as Terry suggests...lots of coats of oil and very thorough drying. Don't know if it will work or not. Krylon Fixative has also been suggested, but I can't find any of that here in the sticks.
Jim Pugh, Ohio
>Carole, Fixative should be available at any art supply/craft store.
What's to lose?
Jack Savona
>Chris, I use Prismacolor markers on my bottle stoppers and pens. Since these are semi-production, I'm anxious to finish them all in one session. After using the marker to color the turned and sanded wood, I burnish with a paper towel, then a paper bag. Usually there is barely a trace of color on the paper. However when I apply Bush Oil (turpentine base) as the piece is spinning I see a coloration bleed on the paper towel. Using (alcohol-based) Mylands, I really see the (alcohol-based marker) color transferring to the towel. I also see it when applying lacquer. I've yet to let everything dry for a day or so. That may be the next experiment.
Now back to your question. If you just want to Beall buff without a finish, I would think the absolute worst would be an ever-so-slight coloration on the buffing wheel. So what? It should occur on the tripoli wheel first so you'd see right away. If any color appears, would it ever transfer? I doubt it. You could dress the wheel with a hacksaw blade and rejuvenate it. A sample buff should tell you.
Playing Vegas odds, I'd try it, but heck that's my nature to experiment a bit with apparently-safe odds.
Jack (with all ten digits...and planning to keep them intact)
Carole in VA
>Yes I know, but we don't have an Art Supply/Craft store here. :) I live in the land of Dollar General and Internet orders. Heck, we don't even rate a K-mart! Used to have one but they went out of business. LOL
