New WoodChat!
texturing tool
texturing tool
texturing tool
>I have a few minutes to kill because my afternoon appoitment is late (what else is new) I thought I would throw this out. What is your favorite method of texturing, favorite tool, favorite technique etc. I use everything from wire brushes, woodburners, sorby tool, etc. My 2 favorite are the Dremel engraver with a rounded over tool. I make random patterns that look more like leather than wood. My other favorite is a round leather stamp that looks sort of like a flower. By stamping hundreds of hits it produces a really nice background texture.
What are your favorites. I may try to post a photo of these textures later tonight.
Re: texturing tool
Re: texturing tool
John Trant (Baltimore/DC corridor)
>I too use the engraver with either a sharp or the dull point installed. I use it in a swirling motion to create a field of texture. I also use this technique to texture the background field of a carved relief feature on a hollowform. My most common texture is created with a rotary tool with a cylinder bit. I make a field of shallow, not quite parallel, V-cuts. Application of a dye enhances the appearance of either of these textures. I am in the early stages of experimenting with pyrography and find it facinating (although not totally controllable yet).
John
Re: texturing tool
Re: texturing tool
>I am also playing with pyrography but more as a texture with light burning, somtimes just dark brown faded to lighter brown. I think there are tons of possibilities. I talked to Bob Rosand this last week at the workshop and he's adding pyrography to a lot of his ornaments. it's pretty cool. Just simply designs repeated many times.
Re: texturing tool
Re: texturing tool
CapeMayMike
>My wife uses pyrography, a dremel tool and also prisma colors to decorate some of my turnings and also her gourd art. I'm experimenting with an air chisel and needle scaler and have the materials to make texturing tools ala John Trant/John Lucas, just haven't gotten around to it. Anyway, my wife does some very nice work with her accoutrements and I'm learning with mine.
Re: texturing tool
Re: texturing tool
Dale Cook
>I've used the needle scaler quite a-bit.I also made a sorby type texture tool with a small sprocket in a handle which worked well if you don't over use it and flatten everything out.I have a woodburner but haven't had time to use it much,but I like the results people have been posting with one.
