Re: Need Advice on Chucks
Rick Allen
>Boxes are often made from 2x2 stock. As such the resultant tennon diameter is just at the closed position of the Oneway Stronghold jaws. The #1 jaws aren't suitable for a box.
The talon is smaller and the closed position of the Talon #2 jaws is smaller than a tennon turned from an undersized 2x2.
So for a good alpurpose chuck the Oneway Talon is a terrific choice and great for making boxes.
For hollow forms I prefer dovetail jaws as I find them to grip tighter the more you crank down on the key. I have found that you can over tighten the Oneway chuck with the serated jaws which will make for a less secure hold as you crank down harder and harder on the chuck key.
Think about the forces that the different jaws exert on a tennon of different sizes.
The Oneway jaws have a wider range of good griping power. The dovetail jaws have a stronger grip at particular tennon diameters.
Good luck
Richard
