We value your privacy.
>Restoration continues on this Powermatic model 143 wood/metal cutting BS I got at an auction recently. It's got a 3 phase motor, looks like a pretty good one - Leeson, 3/4 HP, TEFC, looks almost new. I'm starting to think this machine isn't all that old. Anyway, I was planning on replacing that with a single phase motor until a friend told about static phase inverters - makes the three phase motor run on single phase. There's a company that sells them on eBay, about $90 which is a good bit less than a new motor.
Anybody have any experience with these things? From the ad on eBay, I gather there's a fair amount of power loss in the device but I'm not sure. My friend claims the advantage is that the 3-phase motor will run more smoothly.
>If you have a look at the link below you will see the upgrade I did to my lathe using one of these invertors. If you want any more information please let me know.
What you need to look at is Variable Frequency Drives. They don't rob you of horsepower the way a static drive does. Plus they give you varible speed. There are also quite a few sites one the web that will tell you how to create 3 phase using an old motor. That also eats up horsepower but is a really inexpensive way to go.
>Thanks for the suggestions, guys. I found a new 1 HP Baldor motor on eBay for $150 including shipping, so I'm going with that. It's not much more than the static converter would have been, and that setup (with the existing 3-ph. motor) would have me limited to something less than 3/4 HP.
I'm aware of the variable speed drives but, as it happens, this bandsaw IS variable speed - four pulley positions and a two-speed gearbox. Man, this thing is built like a tank. I don't know how old it is - I suspect it's newer than its appearance suggested at first - but you sure don't see them built like this anymore. Should be up and running by the end of next week.
