New WoodChat!
ADVERTISE HERE - FREE TRIAL
Thimble turning
Thimble turning
Thimble turning
Ed Davidson
>Finally picked up one of those thimble cutters from CS and decided to spend the day trying to master making these minatures. First two attempts in Zebrawood and Padauk cracked...too much grain...not my fault :-). So, for the 3rd try, thought I’d use a little harder material...1" cast acrylic rod. This little guy measures about 1" high and 3/4" wide at the base. It was a challenge to drill out and polish the inside, but after that it was smooth sailing.
best regards,
Ed D.
Re: Thimble turning
Re: Thimble turning
TomW in SouthJersey
>Very nice, delicate touch. How did you attached it to the lathe?
Re: Thimble turning
Re: Thimble turning
Ed Davidson
>Thanks…it was really pretty easy. Attach a waist block to a faceplate using double sided tape. Then CA your piece to the waist block and turn/finish the inside completely and outside as much as possible. Then part it off, reverse chuck using a wooden jam chuck, and finish the outside.
best regards,
Ed D.
