New WoodChat!
Saw Qestion OT
Saw Qestion OT
Saw Qestion OT
David Campbell
>Hate to break out of lurking with an off topic question, but a series of events has led to an offer of a free 20+ year old craftsman table saw. I only know it is belt drive with a 1 and 1/2 hp motor and runs well according to the owners (haven't seen the saw- a contractor's model). My qestion is can anyone give me specifics on adding a good fence? What make, can it be done etc? I have a bench top direct drive delta, but this saw should be a step up IF it can be fitted with a decent fence. The price is right, so my funds should be able to handle putting a good fence on it. Thanks in advance to the group. David
Re: Saw Qestion OT
VEGA
Rob Ceraso
>Hi -
A few years ago, before I decided to buy a Grizzly cabinet saw, I was considering upgrading the fence on my craftsman contractor's saw.
All my research pointed to a fence from Vega that is supposedly made to fit the Craftsman saws and some other. If I remember correctly - the price was in the $200-250 range.
Re: Saw Qestion OT
Re: Saw Qestion OT
James McClure
>I have an old "Craftsman 100" table saw and added an aftermarket fence that Sears used to sell. It went on fine, but only because I added cast iron extensions to both sides of the saw. You may need to drill some holes along the edge of the back of the saw to mount a fence, but in my opinion you should be able to add any of the aftermarket fences that you want to. Good luck!
Re: Saw Qestion OT
Re: VEGA
Les Robison
>I had a Vega fence on an older Craftsman contractor saw and it worked to perfection, once it was adjusted. Stayed in alighment and made accurate cuts.
Re: Saw Qestion OT
Re: Saw Qestion OT
Jim D.
>David,
I am sure I will get "yelled" at for this post but so be it. A number of years back I was given a 8" 40+ year old table saw. Home made legs welded on, home made motor bracket and belt driven. My cost was a new blade. I was a table top modle at one time so has a small table and fence. I have to admit though it is a working fool and will rip oak all day long with the right blade! When I am doing longer pieces I clamp a 6' long level on it to use as a fence and it works great.
My point? Fancy new "super" accurate fences are nice but it is the set-up that counts, not the fence! Make sure everything is is good shape on the saw before investing big bucks in a fence that might be worth more than the saw.
Know your tools and how to use them. Tools being new or expensive does not make your project better.
Jim D.
Re: Saw Qestion OT
Re: Saw Qestion OT
Bill Crommett
>I had a Craftsman table saw, vintage unknown, which I converted with a Beismeyer fence, home edition. This is an excellent fence and is just as good as th beismier Professional grade fence. This saw gave me several years of good service until I upgraded to a Unisaw WITH a Beismeyer fence.
Re: Saw Qestion OT
Re: Saw Qestion OT *LINK*
John Trant (Baltimore/DC corridor)
>I like the AccuSquare Fence I have had on my saw for years. It is easy to set up, stays accurate, and it is easy to set it to a particular distance. The cost is slightly over $200 bucks but can be had for a bit less at Woodworking shows. I highly recommend it.
John
http://www.mulecab.com
Re: Saw Qestion OT
Re: VEGA
>My Powermatic contractors saw came with a Vega Fence. It's done everything I've asked of it and I'm really picky.
Re: Saw Qestion OT
Re: Saw Qestion OT
Paul Porter in Phoenix, AZ
>I have a Vega fence on my Craftsman contractors saw and am very happy with it.
My 2cents
~Paul
Re: Saw Qestion OT
Re: Saw Qestion OT
David Campbell
>Thank you all for the good information. I will wait and check out the saw before I get too excited about getting a fence. The owners wife got a unisaw and joiner used so he needs room and has offered to use his truck to get it to my house, it does not get a lot better. Oh, I am going to teach him to turn bowls in exchange for the saw.. I wonder if she can find a used lathe...Thanks again for all the input, I knew the group would have the knowledge needed. David
Re: Saw Qestion OT
Thanks to all
David Campbell
Re: Saw Qestion OT
Re: Saw Qestion OT
Bruce Wiseman
>I agree. I have the Mule Cab fence as well. It is great and the folks at Mule Cab are friendly and helpful.
Re: Saw Qestion OT
Re: Saw Qestion OT
Eaglesc
>I have to agree with Jim D.
All the "upgrades" and money aren't going to make you a better woodworker.
They may save you time and give you a feeling of well being , but a saw is a tool cut straight lines. Thats it, No more no less.
If the bearings aren't shot what you will be getting will probably a step up from what you have now theiught he vintage is about when Craftsman started going downhill in terms of Quality.
Work with it a while,learn its' idiocyncricies (?).
After a while and a few board feet through the saw you'll be a better judge as to whether it needs a high dollar fence for what you use it on.
If it does not have a link belt, that would be the first upgrade I would do.
Klingspor has 4 ft lengths for $5.00 a foot.Best price I have seen other than HF which doesn't stock them as a store item.
Re: Saw Qestion OT
Re: VEGA
echo8287
>I have an old 12" Craftsman contractor saw.I put an Incra fence on it. Course the fence cost more than the saw did new, but it still cut fine was relativly unused,so I thought I would improve it. Works great now,slightly underpowered but does a good job. I also built a cabinet for it and a rolling base. So its kind of a "pig in a poke". It also has 2 router tables in the wings. Poor mans solution to a nice table saw. David
