New WoodChat!
Help on Woodburner Tips (Long)
Dennis J. Gooding
>Based on recommendations from a couple of people in the group, I bought an Optima 1 woodburning system with two tips from PJL Enterprises. My purpose is to try my hand at using woodburning to decorate and to sign some of my work. Pat Lamusga, owner of PJL, suggested two tips to start with: the PH19M-5/64" Ball Tip and the PH8-Burnishing Tip. After experimenting with these for a while I have come to the conclusion that either they are not quite what I need or that I am hopelessly lost as to how to use them properly. The ball tip seems okay for signing, although it seems a bit coarser than necessary. However, I can't imagine either of them being used to do the delicate work that I have seen posted on this forum. I am looking for advice on specific tips to order and pointers to any how-to books or videos on this aspect of woodburning. Dennis
Re: Help on Woodburner Tips (Long)
I'll be listening to this thread!
Carole in VA
>I have a Colwood Super Pro burner and feel like a total klutz with it. I have burned so much wood trying to learn to be resonably proficient at signing that I think the smell of wood smoke has been permanently embedded in my nose!
William
>Hi Dennis,
I use the Burnmaster Hawk and it has a variable temp setting and accepts a variety of pens/tips. I am not familiar with the one you have, but it sounds like it pretty much has the same features just different brand.
Anyway, I use a "6a" pen and so far, it has worked great. I also use it at number "4" setting, maybe "4.5". I'm still new to it, so I am still learning and experimenting. I believe that different woods will burn differently. That may have something to do with it.
I posted this bowl awhile back. Here is a bottom that I did. Hope this helps a little.
>Dennis
I have been dabling in pyrography now for a year or more. I'm still not good but having fun learning. I still can't burn a signature that I like consistently. It varies so much from the species of wood, mostly how much difference there is between summer and winter wood hardness. This makes it hard to control the pen. I still like my dremel engraver for signatures.
I've played a lot with temperature settings. There are two things I've learned this last year that have really helped me control the lines and burns. One is to be patient. Sometimes a lower temp setting with a slower movement of the pen gives a better look and more control. Sometimes a hot pen with a short quick stroke works.
The other thing I learned is that you can use the knife shaped points like a miniature carving tool. by twisting the pen left and right you can make the cutter tip go left and right and have a great deal of control. It's very much like using the carving knife in leather work. I don't really know how to describe this but if you try making vanes in a feather you learn the control fairly quickly.
If you can get a copy of the last issue of Carving Illustrated ( don't remember the month but I can look when I'm home) They had a full issue on woodburning and it was really great.
Jim D.
>In the summer 2005 issue 31 of Wood Carving Illustrated there are three good articles on woodburning. Is this the issue you are referring to? One article is by Lora Irish, one byDesiree Hajny and one bySue Walters. All three articles are loaded with hints.
I have not tried pyrography but after reading these articles it is getting very tempting!
Jim D.
Yeah, another "It depends" answer (Long)
Molly Winton
>Once again Dennis, which pen you use depends upon what you want to do with it. I have two pens I use all the time. One is the 6A, and the other is 10A. These are pens for the DetailMaster, but I'm pretty sure each system has similar tips. I use the 10A, which is somewhat like a skew or blade, for outlining and signing my work. The 6A is typically marketed for signing your work, but it's too thick for what I like. I use my 6A for LOTS of textures. I use it in a stippling motion for one texture, and also in a slashing motion for another texture. I tend not to use my pens in traditional pyrography methods. From what I gather much of the traditional techniques involve low temp, light to dark scorching for pictures on gourds or flat wood. I BURN with mine. I use mine for relief burning or branding. I want it hot and charring. So, again it depends upon what you want to achieve that will determine which pen is for you. Don't even get me started on home-made brands! Once you know what you want to achieve, then ask someone who does similar work to recommend the pens/tips they use. Hope this didn't just muddy the waters.
Dennis J. Gooding
>Thanks for your help everyone. Molly, I admire your work and that of Jennifer Shirley very much--quite different styles but both very effective uses of woodburning for turning enhancement. Dennis
Re: Help on Woodburner Tips (Long) *LINK*
John U - Charlotte, NC
>Hi Dennis -- I have the same system, and started with it for small decorations an signing. I started with the 1/16" ball (19S) for signing, and the small rounded skew (12) for detail, per Pat's recommendations. I've since added the modified writing tip (19M) and a Razortip Pen with screw terminal connections for a custom-made ni-chrome tip (from Craft Supplies - you will need to buy a M-to-M RCA connector to make this pen fit your burner.
I haven't played seriuosly with any these pens (still on the learning curve), but the 19M is MUCH better for signing than the ball tip. Turn it up slowly until it is red hot, the back off until it is just "not quite" red hot - hold it closer to vertical than you would normally hold a ballpoint pen, and sign at a slow to medium rate.
The rounded skew works well for short detail lines - keep the edge honed and cleaned. If you want to do longer lines, you will need a different pen to do it effectively.
Good luck, and have fun!
John
Optima 1 Pen Styles
