New WoodChat!
Jet 1642 EVS owners
Jet 1642 EVS owners
Jet 1642 EVS owners
Carole in VA
>I cannot see one of these in person but am wondering about the headstock locking lever. I am assuming that the handle (D)in this pic is in the "unlocked" position and that when it is locked, is it out of the way behind the headstock?
Re: Jet 1642 EVS owners
>Carole,
What you see is pretty much what you get. The angle might be a little further down towards the bed. I thought you were thinking Powermatic or one of the other big boys? You can only throw a 15-16" bowl with the 1642 (but you can turn a nice, long leg or stile).
It can be repositioned
Dominic Greco at home in Richboro, PA
>Carol,
Actually, the handle can be swung around the other way so that it protrudes toward the back of the lathe. I have mine facing that way right now. To do so, you need to pull the headstock off, swing the handle around, and re-install the headstock. (A heavy operation to say the least, but not too difficult.) The locking mechanism is a lot like a tailstock's locking mechanism.
Dominic
Carole in VA
>JL, doesn't that handle get in the way??? I WAS thinking about a PM (and at one point even a Oneway) but recent expenses (tree removal, vet bills, etc.) have set me back quite bit. Seems like there is always something demanding the dollars set aside for a new lathe! I can still research the various lathes though, just in case I get a windfall! LOL I am looking at the Nova DVR as well.
Re: It can be repositioned
Carole in VA
>Sheesh, why don't they put it on like that to begin with! Thanks, Dominic.
>You can also slide the headstock all the way down to the other end of the bed and turn something of larger diameter, using a stand-alone toolrest. This lathe will also take a bed extension, if you want to turn bedposts, for example. The mounting holes are already tapped into the end of the bed.
Rick Allen
>Hi Carol
If you think about it you will see that the lever is beyond the 16" swing of the lathe. The lever is MORE than 8" from the spindle.
Good luck with your quest
Richard
Carole in VA
>Thanks, Rick. I really couldn't tell from the pictures. That's the disadvantage of not being able to do a "hands-on"
By "repositioned", he didn't mean you have to take it off and put it back on, it just swings either left or right, locking in both positions. It is unlocked when pointing straight down. I think they put it to that side for the photo so they could add the little "D" label and arrow, otherwise it would be hidden. I have my locked back behind the motor.
BTW, I think you will LOVE this lathe. It is well made, has plenty of power, lots of features, long bed, good banjo/toolrest, etc. If you get one, you might need some help getting it set up. I unloaded and set up mine by myself (took about 30 minutes) but it would have been simpler with another person.
JKJ in East TN
Ric Taylor
Ric Taylor
>Carole,
I see what you are looking at, and it is just an illusion. In the photo it appears that the lever is in the way of the turning stock, but in reality, it is not. It only looks that way because of the angle of the photo, and the two-diminsional limitations of a photo. In reality, the lever is not in the way of anything.
I have a 1642, and I recommend it to anyone.
Ric
Ed in No.VA
>I was really looking serious at the 1642, but all the big boys said spend 500 more and get the 2hp PM on sale. check out amazon the shipping is free
