New WoodChat!
Vacuum chucking
Vacuum chucking
Vacuum chucking
CapeMayMike
>Need some input on vacuum chucking. I've purchased a surplus Gast pump, fittings for the gauge and connections up to the lathe. I have everything except the chuck itself, which I'm not concerned about and the through spindle connection linking the pump to the chuck, which I am concerned about. I'm using a VL300 lathe. Do I purchase the E-Z Vacuum Adaptor or can someone suggest a less expensive alternative, such as fabricating some sort of connection? If you've fabricated something, how'd you do it? Thanks much!
Re: Vacuum chucking
Check Packard
>Back in the days before I had a solid-arbor lathe (i.e., Poolewood: no option for through-the-hollow-arbor vacuum tube), I used a simple and relatively inexpensive setup from Packard Woodworks. ( Click the Marketplace link.) I think it is probably just what you're looking for.
Ellis Walentine, Host
Re: Vacuum chucking
CapeMayMike
>Thanks Ellis. I suspect, from looking at the Packard catalog that you're referring to the E-Z Adaptor. However, when I click on the Marketplace link I don't see Packard. Maybe too many Scotch and Sodas before dinner??
Re: Vacuum chucking
Re: Vacuum chucking
john Lucas
>Here's the EZ vac adaptor I built.
Re: Vacuum chucking
Re: Vacuum chucking
>My lathe came with a bearing race in the hand wheel for a 42MM bearing. I bought on form a local industrial supply house that was double sealed or some such. I bought a brass fitting from Lowes that was threaded on on end, but would not slip into the bearing. I chucked it in my lathe chuck and filed it down to fit the bearing and the using a knife edge file cut two slots for O rings. Drove it into the bearing and connected my Gast pump to the other side. There is a valve that acts to release the vacuum and a vacuum gage. The bearing just slips in and out of the hand wheel.
You might be able to make such a hand wheel.
One thing I was surprised about was how carefully you have to seal all the little leaks. There is Teflon tape on the threads of the hand wheel and an O ring between the hand wheel and the shaft. You have to have an O ring or other gasket between the chuck and shoulder on the shaft. An O ring is a bit thick and soft and may allow for a little wobble, so I cut some gaskets out of thin rubber. I made my chucks and they have to be sealed fanatically. The pump will suck air through the plies in plywood and thin MDF. Seal everything and then seal it again.
Re: Vacuum chucking
Thanks guys!
CapeMayMike
>Good info that will put to use. Thanks again
Re: Vacuum chucking
Pump needed
Bernie
>Have not posted much lately have been very busy.
I do have 2 Robinair Vacuum pumps left. Model 15600
6cfm units 110v with cord and switch. Have sold many
here and to my local club.
175.00 shipped to your door
Bernie
Re: Vacuum chucking
Re: Vacuum chucking
George Van in WI
>Does anyone know if the "wet" vacuum pumps used in dental equipment are adaptable to be used on a lathe?
Re: Vacuum chucking
Re: Vacuum chucking
woodspinner/ Bill Hale
>I do believe they use a resivoir system with no fluids going to the pump. I also believe their pump is high volume low vacuume.
Not sure Bill
Re: Vacuum chucking
Re: Vacuum chucking
George Van in WI
>Thanks Bill, I will check with the manufacturer on Monday.
