New WoodChat!
The Joy of Sharp Tools
Peter Teubel
>I just taught a basic bowl class this past Sunday at the Woodcraft store in Woburn, MA. Six students, all with little experience. As usual, I stated that I was know as the "sharpening Nazi" and that before they could call me over to help, they had to first sharpen their tool. As part of the class, I showed them how to use the Wolverine jig and some didn't have the right tools so I lent them mine.
So they are all turning...going along pretty good. I noticed no one was sharpening their gouge. I told everyone to stop and sharpen...NOW! While they were at the grinders, I got on my soapbox about sharpening...again. Once they got back to the lathes, I heard a collective "WHOA!" from everyone. They all experienced the joys of a sharp tool...at the same time. It was really wierd...like an audience gasping at a good magic trick. The grinders were well used for the remainder of the class.
I think they got the message...
Re: The Joy of Sharp Tools
Keith Tompkins
Keith Tompkins
>Peter, I showed a similar group of six how to sharpen with the wolverine, using a LIGHT touch. While helping one student, I heard heavy grinding sounds from another grinder. "Man, I'm glad that's not MY tool!" I thought. I looked over in horror when I realized it WAS my favorite bowl gouge!
STOP! NOBODY IS ALLOWED TO SHARPEN THE TEACHER'S TOOLS!!!!!!
I'm laughing now, but I wasn't then.
john Lucas
>Peter I think the hardest thing to teach is how to know when the tool is dull. Or at least not as sharp as it should be. I teach them to take as small a cut as they can. If the tool slips out of the cut it's probably dull. Of course this can be due to poor cutting technique as well but it gives them at least one method for checking the tool.
Rick Allen
>I have found the fastest way to learn when a tool is dull (or dulling) is to have two identical tools. Start with both tools sharp. If you have any issue while turning switch to the other sharp tool. Sometimes it's because the angle of attack is less than perfect. And sometimes it's because the tool is dulling. When you can check the sharpness of the tool as quickly as picking up another gouge you quickly learn when it's the sharpness of the tool or the technique being used.
Recently HSS turning tools have been comeing from China. You can get a pair of good quality HSS 1/2" (Penn State calls it 5/8") bowl gouges from Penn State for $41. That is less than single simulalrly sized bowl gouge from the English makers.
Mike Schwing from Md.
>I find that a lot of turners have a bit of hand tool experience, whether it be with chisels or handplanes. It seems to help pound the importance of sharpening home when I ask them how many chisel swipes they normally get before they need to strop/hone/sharpen their chisel or plane blade, then ask them to guess how many equivalent "swipes" their gouges are making in between sharpenings.
Peter Charles Fagg (UK)
>I shall never forget the experience of having sharp tools!
For nearly 2 years I had struggled with sharpening my tools on a 6 inch grinder without any aids. (My hands tend to shake uncontrollably when concentrating) I then invested in the basic Tormek and the revelation was so wonderful, the difference between chalk and cheese!
Now whenever I have the opportunity of showing students the difference I can relive the same pleasurable moment all those years ago.
Regards Peter.
JamieDonaldson
>I did a workshop with John Jordan years ago, and he had a saying that I teach to my students. When you begin to have trouble with a tool or piece of wood acting up, 90% of the time it's because the tool needs sharpening. It's amazing how the break to sharpen the tool also adjusts your attitude, and the improved edge and attitude really help smooooth out the process!
Joe Fleming
Joe Fleming
>I always explain it this way. If an apprentice joiner is pushing his/her Bailey #8 all day (say 8 hours), he/she will cut about 2 miles of wood in that day. And they will have Popeye-like forearms.
If you turn a 3" baluster at 3000 rpm, your tool will go the same distant in about 4 minutes. And genrate a HUGE amount of tool damaging heat.
Moral - sharpen often.
Joe Fleming - San Diego
