New WoodChat!
Walnut Bowl Problem?
Stan Campbell
>I was wondering why no one suggested using thin Super Glue to soak the trouble spot?
Stan
Re: Walnut Bowl Problem?
john Lucas
>Stan I do use it sometime but it inhibits certain finishes and it's expensive consequently I usually use other methods first. Since I often finish with Lacquer I use diluted lacquer quite often for stiffening fibers. Most of the time a good sharp tool and light cuts will take it down to the point that light sanding will remove the problem
