New WoodChat!
3 Wheel Buff For Less
Stuart Johnson
>There was another topic regarding which buffing wheels to purchase, Beall or other brand. This is a shot of a 3 wheel buff I made for a total cost of $41.59. The commercial ones cost around $90.00. I'm sure the hardware can be purchased for less than what I paid at my local ACE hardware store. The buffing wheel are from http://www.caswellplating.com . I don't want to get into a which is a better price Beall or these but these work fine and did not need the hole enlarged to accept the 3/4" all thread rod.
I also have the regular Beall set-up and if you were going to just use one at a time recommend it.
Re: 3 Wheel Buff For Less
Eaglesc
>AWWW, go ahead Fred!
ben d
>Are all 3 wheels the same material.?? If not what type wheels did you purchase.?? pn. from caswell if you still have it and what is the thickness of the wheels. Just full of questions.
thanks
Stuart Johnson
>The tripoli and white diamond are both cotton. The one for wax is flannel. I have a .pdf file showing how I put it together. If our are interested I'll stick it on a web page and you can download.
And Morse tapers . . .
Fred in NC
>I have seen a lot of buffing setups that use a metal adaptor or a drill chuck. The drill chuck will work ok, but it is one more piece to be dealt with.
Morse tapers can easily made out of hardwood. For this use, it does not have to be an absolutely perfect fit. A HARDWOOD dowel, about 1-1/4" dia. can be used to make the taper. I copied the angle by measuring with calipers, and turned the taper about 2" long, leaving an inch or so at the full diameter of the dowel. Then the taper is sanded with an 80 grit gouge (sandpaper on a piece of plywood).
With the taper in the spindle, a hole is drilled to take the threaded rod. Tapping is optional.
Remember, the wood will not damage the spindle like a poorly made taper would. The tailstock will hold the taper in place.
