New WoodChat!
End grain hollowing - coffee scoops?
Tony - Memphis
>I was playing around this weekend trying to make a coffee scoop similar to the ones Ruth Niles made in the article I found online. Had a bit of trouble with the hollowing. I got it done, but my method wasn't pretty! Any tips?
I used a combination of a bowl gouge and a scraper. Never could get the scraper to "act right" especially near the bottom.
Thanks for any tips/suggestions.
Tony
Re: End grain hollowing - coffee scoops?
>Tony
Most people have problems at the bottom because the get the scraper tilted up a little. The cutting edge still needs to be slightly lower than the handle so you are cutting with the burr. The center can be difficult. I try starting just below the center nub and then lift the cutting edge straight up until you remove the nub, then swivel it to the left. If you get to the right of the nub it wants to lift the tool off the tool rest so avoid this at all cost.
Thanks....
Tony - Memphis
>Is that a good method to hollow? I first drilled a hole with a regular gouge, then used a bowl gouge to get the majpr meat out, then used the scraper. None of this went well though! I thought I might drill a bigger hole, then just finish it out with the scraper. The scraping went ok, but still not very elegant. I definitely need some lessons. I use the lathe 99% for making furniture parts and am not real good at that. So this hollowing business is very new to me. I have no intent of doing a lot of stuff like this, but it is fun to make some small things like coffee scoops and such now and then. Good gift items too.
Thanks for the help.
Tony
Re: Thanks....
Fog Tanner
>The main thing is a lot of practice. I use the Raffan "back hollowing" for getting rid of most of the wood. Then a Raffan style "box" scraper, a round (more or less) nose scraper which has an edge going down the left side. With the scraper, I start with the rest at or above center and the edge of the scraper at center. I can bring the tip up through the center and then through an arc across the bottom and abd back to the center line and flow into the side. As I bring it up the side, I turn the scraper, so I shear scrape. On some cedar pieces, I don't have to sand as it scrapes so clean. The back hollowing is something that is difficult to describe and makes more sense when viewed. Raffan's Turning Wood video/DVD is a good source or his Turning Projects. One of the two shows Richard making a scoop. During a hands on workshop, I asked him how long it takes him to turn one the scoops in production mode. There was a slight smile and he replied fourteen seconds. But, he has also made over 40,000 of them and will probably still be able to turn them two years after he leaves this rock.
Another method is the Ray Key style gouge, but there again you really need to see it used. I bought two if his style gouges for pieces where the back hollowing technique was not the right one to use. I had to watch Ray using the gouge to understand how it was meant to be used.
Again, it just comes down to a lot of practice, and after you get through then some more practice. The practice pieces that come out nice can easily turn into gifts, the ones that didn't are a leaning experience and a comparison for what not to do. I keep all those as a reminder of what not to do, hopefully that box will quit growing someday or at least slow down....
Fog
tek-Brunswick, Ohio
>I haven't mastered the Raffin Backhollowing technique yet. It is very fast if done in the right manner. I hollow Chris Stott style. I drill my hole with a 3/8" spindle gouge with a fingernail grind. The Flute should be turned away from you. With the tip of the gouge in the very center of the axis push the gouge strait into the end grain. The end of the handle opposite cutting end should be pointing at your tail center. I wrap tape around the gouge to mark how deep to drill. After the initial hole is drilled use the same 3/8" spindle gouge or a 1/2" spindle gouge to hollow. Work from the hole towards you with the gouge rolled on its side. The flute should be facing you when hollowing this way. Hollow in steps working your way to the bottom. It is not as fast as the Raffin Technique, but I find it easier to control. Then finish up with the scrapers. The scoop in this picture was hollowed this way.
Tom
Don Henthorn
>I have made several of the coffee scoops (thanks Ruth) and I have found it pretty easy to hollow just using a 1/2" round nose scraper ground to a 30 degree bevel. I do a little shear scraping on the bottom and as farr up th side as I can.
Re: Thanks....
Barry Turner
>You can do a decent job hollowing with a 1/4" or 3/8" fingernail spindle gouge. I just can't make a bowl gouge wok right hollowing a small item.
Thanks All!
Tony - Memphis
>I'll keep at it. I'm not real clear on using the spindle gouge, but the angle is a clue I had not realized. I was watching a video by the elderly English fellow? and I remember him showing the angle. Guess that's a key when using the spindle gouge for that operation. Are you cutting on the side of the gouge then?
Tony
Re: Thanks All!
tek-Brunswick, Ohio
>Yes, with either the Raffan or the Stott technique you cut with the side of the gouge, once the depth hole is established. Don't try to use the whole side at one time. Cut with the front 1/3rd or so up by the nose. A lot of it is learning to feel what your tools are doing and that takes practice. After I replied to your post I went down to my lathe in the basement and tried the Raffan technique. I'm starting to pick it up. I'm still more comfortable with the Stott style hollowing, maybe because that is what I learned first and have more experience with that.
Tom
Thanks
Tony - Memphis
>Yeah, I need to just devote some time to learning and practicing. My time is so limited, I rarely do that though. And I mostly turn furniture parts, so this sort of thing comes second. But its fu to turn a coffee scoop or a pen or a small cup to hold screws now and then. Some of those offcuts from making flat work have some real nice figure and you hate to throw it away!
Tony
