New WoodChat!
Bad idea??
Bad idea??
Bad idea??
Spence in Rhode Island
>Being the cheapskate swamp yankee that I am I had an idea this morning to get some more use out of a pink grindstone wheel that's less than 5" in dia. In order to take advantage of the flat side of the wheel I thought of turning a wood form and gluing the old wheel into it. In use it would be mounted on the lathe and spun around 1,000 rpm or slower. Since one side is fully supported by wood and epoxy I figure there is less chance of it flying apart. What do you think? It's been suggested by those who know me that at times I'm not only a danger to myself but society in general. Am I once again proving the point? LOL
TIA
Spence
Re: Bad idea??
Steven Antonucci
Do you really want that mess all over the Lathe?
steve antonucci
>I've always gone by the thought that if I have to ask if it's a bad idea, it probably is...
Aside from a huge mess, what would you expect to gain from this effort? When I grind on my belt sander, I find magnetized steel filings everywhere. I don't think that having them stuck all over the ways or even worse, the spindle, makes me want a 5" grinder that bad.
My opinion as a recovering packrat is that the sooner you throw it away, the sooner you can get on to the next big thing. Now if you'll excuse me, I have a box of old tool parts to throw away...
Steve
Re: Bad idea??
Re: Bad idea??
Ken Grunke from SW WI
>I've had the same idea, but I would make a horizontal, slow speed, wet grinder. My thought was to mount it in a drill press and fabricate a frame to bolt onto the DP table, which has a water pan and a toolrest for sharpening planer blades and maybe skew chisels. Still a pipe dream, as I haven't gotten a round 2it yet.
Re: Bad idea??
Re: Bad idea??
>I mounted mine on one of those antique hand powered grinders. I use it when I'm demonstrating my pole lathe, as more of a joke than anything else but it does work. It doesn't work well on bowl gouges that need to be swept from side to side because the handle gets in the way. I've been thinking about building a ratcheting handle for it.
Re: Bad idea??
Re: Bad idea??
Don Evans
>Think foot pedal John.
Re: Bad idea??
Ummm. What are ya throwing away? LOL
>Steve The amount of grinding I will do on it would be very occasional. Just an idea that came to me. HAve a coulple of carving gouges that I want to ry to save. Just thought this was a different way to grind them flat. Now about that box of parts..... ;)
Re: Bad idea??
Re: Bad idea??
>Hhmmmmm.....Could you use a norton pink A/O wheel wet? Thought of the drill press myself but the angle on the lathe would be more comfortable for me. I'm more worried about shrapnel than anything else.
Re: Bad idea??
Re: Bad idea??
>John if you use the sprocket and gears from a bike with a short piece of chain it would leave both hands free. I helped make a foot powered lathe like that with a concreate flywheel. It was a bear to get going but once you did it only took a few pumps to keep up the speed. Worked pretty good too.
Regards
Spence
Re: Bad idea??
Re: Bad idea??
JamieDonaldson
>OK John- I can hear the gears grinding- will it be 18 or 21 speed??!!
Re: Bad idea??
Re: Bad idea??
>I think it would be safe if balanced. I would test it at a higher speed, wear eye protection (of course), and stand out of the line of fire while using it.
However, I'm not sure the utility would be worth it to me. I think I'd get more use out of a sanding disk for both sharpening and sanding (if I didn't already have one).
JKJ in East TN
Re: Bad idea??
Steven Antonucci
Haven't thrown it away yet :-)
steve antonucci
>Upgraded my Craftsman bandsaw with a 1HP motor (makes it usable), so I have all of the hardware from the hanger assembly. More door hinges than I could ever want. A wide variety of parts from tools that died, including all of the bearings (just in case I need them...)
And then three tins labelled "STUFF".
Steve
Re: Bad idea??
Re: Bad idea??
>Have to agree John that it would be easier to use a sanding disk. I must have about a dozen in the shop with all different kinds of grits so there is no real "need" to do this other than out of curiosity on how it would work. As for saftey there was a line from an article by Denis Elliot in Fine Woodworking many years ago about his turning huge burl wall hangers. "One of these days... POW right in the kisser!". I think he got it from the TV show "The Honeymooners". Its an oft repeated mantra when ever I turn the lathe on with a new project. So far so good. LOL
Re: Bad idea??
Re: Would Those Include
>The old power cords with molded plugs? |;-}}}
