New WoodChat!
mini: Jet vs Delta
mini: Jet vs Delta
mini: Jet vs Delta
>I may have the occasion to do a demo where I need a portable lathe so I looked today at the mini Deltas and Jets in Woodcraft. The Delta is a few dollars more but not enough to hurt.
They look almost identical, except Delta has the power switch on top and perhaps better access to the belt for speed change. Woodcraft said they've only had one problem, a motor on a Jet, but suspected it was from abuse. (They use Jets in their classroom, probably because they are a bit cheaper.)
Delta doesn't make a stand, but it appears it will fit on the Jet stand. It would probably not get heavy use.
Any words of wisdom? Experiences? Thanks.
JKJ in East TN
Re: mini: Jet vs Delta
Fred in NC
>I have a Jet Mini, and happy with it. One thing about Jet, it has been easy to buy parts directly from them.
Carole in VA
>I like my Jet. I wish it had a little more ram travel in the tailstock, but it does have a little more than the Delta (2" vs 1 1/2" on the Delta) Personally I don't like the switch location on the Delta. Sometimes I have a need to rest my forearm on the top of the housing. Also with the Jet, I can hit the switch with my hip if I need to and don't have to reach over the spinning work piece. Since I am right handed the Jet switch location is very comfortable for me.
Barry Turner
>The Jet wins hands down! I've used one very hard for almost 4 years now with no problems. Well, I had one. The setscrew on the tailstock handwheel came loose a couple of times. A drop of Loctite fixed that. Personally, I looked at both lathes, plus a few more. I came to the conclusion that the fit and finish was better on Jet. My Jet mini is smooth, quiet and gets the job done. What more can you ask for? My Jet Mini will always have a place of honor in my shop........right next to my Stubby.
Bob Watsek
>Jet gets my vote. Before I bought my Jet I read several reviews on mini's and one of the raps were on the Delta tool rest adjustment handles locations. I visited a local Delta dealer who had floor displays and I could see where the reviews were coming from. I went Jet.That being said I broke the post on my tool rest after a catch which I understand Jet is prone to so I bought a aftermarket and had no problems since and I'm very happy with the Jet.
Conclusion both are good lathes but both can be improved.
Bob Watsek
Mike Rubes, Apex, NC
>Hi John,
I really think it matters most which color you like best :) That said, I've had a Jet for 3 1/2 years and love it. The only issue I've had that wasn't an adjustment on my part, was I stripped the belt and had to replace it. It really wasn't a big deal. I've really put the Jet through it's paces and have roughed bowls that were 9.5 inches across and 4-5 inches deep and it never complained, just kept spinning.
One other odd thing. I was once turning some padauk on a hot, sweaty day and was resting my forearm on top of the headstock while working the tool in on the bottom of the bowl. There must have been something between the sweat on my forearm, the finish on the lathe and the padauk dust because they combined to stain my arm and the top of the tailstock this lovely shade of purple. The stain on my arm eventually wore off, but I cannot get the purple color off the top of the headstock! It is slowly wearing off (like Carole, I rest my arm up there a lot), but I tried paint thinner, steel wool, etc and could not get it off.
So, while it may not win any "pretty lathe" contests, it's rock solid and really gets the job done.
Good luck, let us know what you decide.
Mike
Didn't even mention the countless shellac and oil stains/spills on the lathe in Apex, NC...
Bob Elliott
>My vote is for Jet. I bought one back on 12-31-97 & it's still running strong!
If you buy a Delta, be prepared to bend over if you ever have to purchase replacement parts.
Yes, the Delta will fit on the Jet stand.
Lowell Converse
>If you can find one, I suggest you take a look at the General maxi-lathe before you decide.
Don Orr
>Please don't take this the wrong way but I would steer clear of the General and get a Jet. I've had a Jet Mini for 5 yrs and have used it hard with no trouble at all. Our club has several General Maxis that we use for workshops and we have had trouble with every one right out of the box. Several friends have had the same experience. In my OPINION General Maxi is not worth the trouble or the price when you can get a great little lathe from Jet. Again just my opinion and experience FWIW.
P.S.-no experience with the Delta.
>John I've used just about every mini on the market except the General and really haven't spent much time with the Delta. I liked the Fische lathe a lot but they just don't have the dealers to back you up. It's very similar to the Jet but the motor didn't seem to get as hot and belt changes were very easy. I liked the Vicmarc VM100 a lot partly because you can supply your own motor which gives you a lot of choices.
Out of all the ones I have been on I would probably go with the Jet simply because there are so many out there and even though there have been some problems there haven't been that many when compared to the numbers of lathes out there. I like the Delta, it's very similar to the jet and they've always worked with me well when I needed repairs of other tools there just aren't enough of them out there to know there history. Either they work really well and no one is reporting problems or there simply aren't enough out there to report on. That makes me a little leary.
Thanks for the help!
>Thanks, everyone.
My Woodcraft dealer has a Delta herself and loves it, but said either will do the job. I did like the fit/finish on the Jet a bit better than the Delta. (This must be all the way up the lines - the fit and finish was one reason I bought a larger Jet rather than a Delta.) I guess if I get the Jet at least the paint job on the stand will match. :)
JKJ in East TN
Re: mini: Jet vs Delta (long)
Rick Allen
>The Jet and Delta are similar lathes and if I was given either one I wouldn't consider trading it in for the other. There are some differences. I teach an Intro to the Lathe class at woodcraft. We use Jet Mini, Delta Midi, Jet 1236 and Delta 1236 lathes. I have observed the following differences between the Jet mini and the Delta Midi in the 4+ years I have been teaching the class.
The Delta weighs more than the Jet the casting on the Delta is thicker than the jet. This only amounts to a few pounds and likely doesn't matter in the long run.
The Delta has more distance between centers. Not much, perhaps an inch. Sometimes that inch matters a lot though.
The Delta toolrest and tailstock lock more securely than the Jet. There is a fix for the Jet in the form of a square piece of steel replacing the round piece that contacts the underside of the ways.
The switch on the delta is on the left which encourages you to get out of "the line of fire" when starting the lathe (right handed). The Jet switch is known for failure and the way the jet switch protrudes makes it easy to damage in transit. The Jet switch can be easily replaced. Any SPST switch rated for 125 Volts and 10 amps will work fine if you can mount it.
The top of the Delta headstock is round and it has that switch box in the way. You can place things on top of the Jet headstock.
The top of the jet tailstock is also a place where you could set something if needed (not with the lathe on...)
The motor on the Jet has a better class rating than the Delta. The Delta motor has fins on the motor which makes cleaning the shavings off the motor more of a chore.
The latch for the door on the Delta is known to fail. I have not seen or heard of an easy work around for this latch.
The Jet will eject a shorter MT live center than the Delta. This is to say that a Jet live center can get stuck in a Delta tailstock but a Delta Live center can't get stuck in a Jet tailstock.
The knob on the knockout bar for the Delta prevent it from falling through the hole provided for this. A fix for the Jet is to drill and tap (soft cast so this is an easy matter) a hole under where the knockout bar goes into the jet and then thread a long screw from the inside so the knockout bar can't fall through the Jet.
The toolrest on the Jet can be over tightened more easily than the Delta. There is more flex in the Jet banjo cam bar and in the Delta,
I have seen a Delta with a cracked casting and I have not seen a Jet with a cracked casting.
There are more third party accessories available for and being developed for the Jet (duplicators which are generally a bad idea, Spiraling attachments.)
The Jet is available in a Electronic Variable Speed model.
BTW Woodcraft guarantees everything they sell for a year. If you get the Delta and within the first year decided that the Jet was a better choice you can return the Delta and get the Jet (or the other way around). If you break the tool rest in the first year Woodcraft will replace it free.
So there are differences between the two lathes. For me all those differences com out as a wash. But you might find one or more of those difference to be reason enough to select one over the other.
Good Luck with your choice.
Richard
Lowell Converse
>Oh my. I have a policy to never get involved in a bickering match over choices of equipment. I suggested John take a look and make his own judgment without offering any reason why. Figured he'd been in the business long enough to not need my help in evaluating features. That being said, here's why I traded my Jet, which I had for 2 years, for the General. The General is 30 pounds heavier, a very important feature. And it's still not too heavy to take for a demo. The quill lock clamps on the quill instead of pressing against it. How many Jet and Delta users have not occasionally had problems with the quill lock. I have to make a point of how to lock the quill on the Jet whenever I teach at Woodcraft where they use the Jet (Dayton, Columbus, and Cincinnati). I find the tailstock lock and the banjo lock notably more user friendly on the General. My opinion only, of course. I have owned both the Jet and the General, and have turned often on the Delta. All are acceptable lathes. And ALL require a few modifications and adjustments out of the box to work well. John can't go wrong with any of them, but personally weighing features and benefits of ALL contenders seems worthwhile. No affiliation with General, in fact, I sold my 1 hp 260 for more hp. Great lathe otherwise.
>Thanks again, everyone who wrote (and for a couple of emails as well). Great info, as usual - a bit of experience is worth a whole bunch of hype! I picked up a Jet mini and will try it out tonight.
JKJ in East TN
