New WoodChat!
Veritas - Innovation in Tools
finial on hollow form
Dick Hines
Dick Hines
>I just finished a cherry follow form and decided to put a finial on top. I turned one out of blackwood that I am happy with. The question is should I glue the finial on or just let sit on top.
I had a nice tenon on the finial but it was a hair to big. I enlarged to hole in the hollow form and sanded it and now the hole is just a hair to large. If I keep the piece it will be OK but if I sell it I will have to worry about the finial every time some one pickes it up to inspect it.
Glue or not to glue? That is the question.
Re: finial on hollow form
Glue
Jennifer@Indy.USA
Re: Glue
Carole in VA
>I am assuming that on something like that you would use some sort of flexible glue, or is regular old yellow glue flexible enough to accomodate movement?
No Glue
Barry Turner
>Well, I can't speak for everyone else, but if I bought that vessel, it would drive me nuts not being able to look inside.
Re: No Glue
Carole in VA
>All the more reason to glue it! Hard to sand inside those things. LOL
Re: No Glue
Barry Turner
>Of course it is! Why do you think I wanna look inside?
HMMM...
Fred in NC
>Reverse tumbling? put steel balls and some grit inside, and TUMBLE !
hehe !
Re: HMMM...
>My 2 year old Nova DVR will run at 250 RP M's, the new ones will run a 100. Been trying to figure what I would do with 100 RPM's. You just hit it Fred. Put a hollow form on the lathe with some abrasive inside and let it run for about a week. Use finer and finer abrasive and you could tumble the inside SMOOTH. Good thing for the lathe to be doing while I'm out earning the money that supports my turning habit.
Dick, If I glued the finial on I think I would put a bead inside so it would rattle. Otherwise there are people that would assume it was solid. Dry 'em nuts.
woodspinner/ Bill Hale
>Dick
Seems to me this is YOUR decision.
I personally would not glue. You said it was a hair large. How about a thin layer or two of CA on the tennon to enlarge it to fit ?
Good turning and be safe
Bill in Casa Grande, AZ.
Dick Hines
Dick Hines
>Thanks for the ideas. The one about the sand would not work though. There some small worm holes. I can see the sand all over the place now.
Looks like it's about 50-50 on to glue or not. Guess I will have to give it some thought.
