New WoodChat!
Boring Deep Holes
Boring Deep Holes
Boring Deep Holes
Barry Turner
>Can someone give me some tips on boring deep holes for pepper mills? I plan on using Forstner bits with extensions and boring on the lathe. Anything else I should do of be aware of? Thanks.
Barry
Re: Boring Deep Holes
Rick Allen
>Hi Barry
Ship Auger. Drill a pilot hole first so the lead screw of the ship auger doesn't grab hold. You can get ship augers in lots of sizes and two lengths. There is a single cutting edge so it is fairly easy to sharpen. The ship auger is also a big stiff piece of steel.
Good Luck
Richard
john Lucas
>Barry
I use a forestner bit. Crank the speed down and pull the bit out often to clear the chips. If you don't it will lock up in the pepper mill and the only way to get it out is to cut the mill open. My "friend" had this happen.
Barry Turner
>Thanks, I'll be extra careful. By the way, does your "friend" have a Powermatic 3520A?
john Lucas
>Yes and he does photography too. In fact My "Friend" causes a lot of problems that "I" of course have to solve. John
Bob Elliott
>If using a forstner bit, you might try drilling from both ends. I've found that if I drill straight through, the exit hole is not in the center of the blank.
Also, you will probably need some sort of extension.
Les Robison
>I purchased a 1" diameter Brad Point bit from Craft Supply. I like it better than Forstner bits because it does not clog when you are doing deep drilling. It is 6" long.
>So, I guess you could say, DAMHMFKT?
Barry Turner
>You're gonna have to clue me in. What does "DAMHMFKT" mean?
Barry
Re: Variations on a Theme
>The theme is DAMHIKT, which is an acronym for "Don't Ask Me How I Know That." I guess you could call it the equivalent of a teaching degree from the "School of Hard Knocks."
The variation, DAMHMFKT, means "Don't Ask Me How My Friend Knows That." In other words, Take this sage advise at face value, because neither one of us really wants to discuss how we chanced upon this primordial truth.
