New WoodChat!
building doughnut chuck ?
ken chase
>As per the instructions I'm truing up the two sections of the chuck while they are bolted together. It appears true but I still get a slight wobble. Is this normal or should it spin smooth as a black would after being trued. This is the first time I've worked plywood on the lathe.
Thanks
Re: building doughnut chuck ?
Was the ply flat?
Carole in VA
Re: Was the ply flat?
ken chase
>I thought so. But now you have me thinking maybe not. I couldn't
find a small quantity of baltic birch where I live so I just used
some plywood I had. I also can't find foam latex for it so I thought
I'd try some polyurethane foam insulation.
Thanks
Don Henthorn
>Ken, for what it is worth, I trued up the face of the base disk so that the top of any bowl sitting against it would be at 90 degrees to the lathe's ways. Then I put the outside disk on and trued up the edges of both disks. As far as I can see that is all that is needed.
john Lucas
>Ken
I don't know exactly why but almost everytime I put a piece of plywood on the lathe it doesn't run true. I simply true up the front surface unless it's a large piece then I true up the rear as well to keep vibration down. They usually aren't off much but a even 1/16" drives me nuts. While your at it put some small grooves about every inch on the face of the chuck to make it easier to align the bowls.
I put a scrap 1x12 on the face of mine when necessary and cut a slot to accept the bowl for alignment. I usually only do this if the base needs to be absolutely perfect. Usually just aligning it with the grooves is good enough.
Re: building doughnut chuck ? *LINK*
Fred Holder
>Hello Ken,
The first time I saw what has become known as the Donut chuck was in Vernon Lebrant's shop in Everson, Washington about 10 years ago. Vernon turns large bowls up to 3 and four foot in diameter. He had a fairly long board that mounted to his faceplate and had two holes that matched the unbreakable plastic disk that he had with a hole in its center. Vernon turned a groove to match the size of his bowl in the board. Then two long bolts went through the board and the plastic disk with the bowl captured between them. The bowl was automatically centered to the center of rotation of the lathe by the groove. The plastic disk served to hold the bowl to the board. The foot of the bowl stuck out of the hole in the plastic disk so that he could final turn the foot.
I subsquently used this technique several times with a 2" x 6" board mounted to a faceplate and a plywood disk with a center hole serving to hold the bowl against the groove in the 2"x6" board. It didn't really matter whether anything was flat or not. The groove cut in the board was square with the axis of rotation and that is what positioned the bowl. It didn't matter whether the plywood disk ran true or not, it was only pressing the bowl against the backboard groove.
Incidentally, Vernon only used two bolts and so did I. The bolts serve to pull the donut disk toward the backing disk and thus hold the bowl in the groove. The groove cut in the backing disk determines the contricity of the operation.
Hope this helps some.
Fred Holder's Domain Site
Shelgra
>Having trouble visualizing the set-up. Could somene post a photo or drawing of the "fairly long board with a groove in it"? Thanks in advance, Shel
