Re: Lathe Spindle Morse Taper Scoring *LINK*
>Roland,
A #2 Morse taper Hand reamer will resolve your problem. Check with a "friendly" local machine shop and you may be able to borrow one for a day. With the lathe OFF, the reamer is GENTLY inserted into the taper and then GENTLY rotated with light hand pressure and a open-end or crescent wrench. Take 2 revolutions, remove the reamer, clean off and shaved metal, reinsert, and repeat several times until the reamer makes even contact in the taper without "catching" when turned. Stress "gently" here because you can really screw up your taper by overdoing this.
Once you have the spindle taper restored, you must carefully clean and de-burr the drive center and any other appliance you plan to use. Failure to do this will recreate your current problem all over again because the defect in one will transfer to the other.
You can prevent this in the future buy cleaning both tapers and the inserts (tailstock too) before each use, making sure that any burrs, scratches, dirt (including wood dust), and grit are removed. Packard sells a urethane rubber item called the "TaperMate" that looks just like the reamer and will remove dirt from the female tapers which is probably what caused your problem to begin with.
If you can't borrow a reamer from a shop (local turning clubs often have them as well), ENCO (link) sells the #2 for about $26 plus shipping. Thing is, if you're careful about keeping things clean, you'll never need the reamer again. Wicked thing that looks cool on the tool board though |;-}}}
Note again that the reamer is only for repairs, not for routine cleaning the tapers; overuse will reshape the tapers and throw your machine's alignment off until you go buy a New Spindle and quill (not a good thing).
ENCO -Reamer
