We value your privacy.
>Just out of curiosity, does it make any real difference what kind of finish (smooth vs rough) you leave on a roughed out bowl blank?
I've been in the habit of praciting my technique on rough outs, shear scraping, etc. I figure I get 2x as much practice per bowl blank this way. I can't imagine it makes any difference to the drying time/success, but I've been wrong a few times in the past, so thought I'd ask. I currently dry blanks in one of four ways. Alcohol, anchor seal the end grain, bag of shavings, or forgotten on the floor behind the lathe for a month or two (this technique often includes both shavings and anchorseal drips, though that's generally not intentional)
>I don't se any reason to clean up your bolws if you are just rough truning wet wood. Since you are ging to retun them anyway just rough them out and dry. You can be more careful when you return them.
>Dave I don't turn a lot of bowls but on my last batch of 10 rough outs I left them really rough. I roughed them as fast as I could and often forced the tool through the wood. only one box elder piece cracked and it may have had that defect when I roughed it because it was near the end of the log. I only sealed these on the endgrain.
>I also anchorseal the entire surface, unless there is some bark. For those pieces where there is some decorative bark left on the piece I avoid coating the bark since the wax will not be final turned off the entire bark surface.
Also I get each rough piece pretty smooth. As you indicated it doesn't take that long. I figure it is some small practice. Plus a smoother surface will not have tearouts (from aggressive roughout work) and this leaves some small options for final turning the piece.
>I was reading about drying lumber in a USDA book on the subject. There has been research on planing the lumber before it was dried. I can't remember the results, but they had several arguments. One was that by dressing the lumber, it could be reduced to very uniform thickness and therefore eliminate the slight unevenness of good sawing. This would make the stack neater and more accurate, with less waviness caused by poor sawing. This would have no impact on turning.
Another thought was that the flatter smoother surface would somehow dry quicker and would have less flaws to impart into the wood. Not sure about the drying quicker, but removing the flaws seems to be a good idea. If you completely cut away a crack or other defect, it will have less impact on the rest of the blank. I believe the results on the flat work were that it may have been a little better, but not enough to make it worth it. You had to make the lumber a little thicker to allow for planing and then still have enough wood left to flatten the planks later and plane them again. I think they called it something like "Bunking".
I Core my bowl blanks and usually take one pass with a gouge just to clean up the surface and even out the thickness. I find that if I make the rim 1" thick, I can make the bottom 1/2 or 5/8" and be fine. I put most of them in a paper bag and lose them for a while, or turn them green to finish.
