New WoodChat!
Bowl needing haircut
Jack Savona
>Rough turned some three-week-old poplar yesterday. REALLY wet, as in indoor shower! End grain was SO long on the sides, I thought of braiding it.
My problem was getting my tools to cut. Fingernail gouge, scraper...it didn't matter. Every time I put as newly sharpened tool against the wood, the tool couldn't cut. Wood fibres immediately covered the tool edge and prevented it from reaching the wood surface. Extremely frustrating. Anyone had this experience? Any e-z solutions? I've got enough logs for ten more bowls, but I don't want to go through this experience again. Ain't no fun.
BTY I have soaled one bowl in DNH, one in LLD and boiled one. It'll be interesting to see how each behaves and how its end grain cuts when dry.
Thanks in advance.
Jack (in the rain in Maine)
Re: Bowl needing haircut
David Propst
>Hi Jack,
Fresh wet poplar can be a real hoot to turn, but what you see with stringy endgrain is also common with very wet poplar. Keeping your tools as sharp as you can get them and bevel rubbing is my best advice. It will be easier to cut when the wood dries.
Best Regards,
David
Sam Dean
>Hi Jack,
David is right, keep the tools as sharp as you can. It will turn much easier when dry! I turn a lot of poplar, and the best cut I have found is a bowl gouge with side grind with the handle held down about 30 to 35 degrees. The more of a shear you gan get, the cleaner the cut will be. The hairy grain can be hard to deal with until you get a smooth cut.
As far as drying, I just chuck the poplar in a pile and let it dry as fast as it pleases. I might loose 1 in 20 pieces from cracking, but that's it. It's some pretty stable wood.
Thanks,
Sam
Bob R
>Sam
I have a lot of poplar here now after a storm. Have never turned it. I have seen some great looking stuff from poplar so would like to turn it. Question? How long do you cut your your wood? What lenght? How long do you let if dry? Days, weeks, months?
Do you rough turn and then soak or what?
Bob R
PS Your bowl looked great.
What was the finish?
