New WoodChat!
Need a source of supply
Dave Anderson Chester, NH
>I use Snakewood for making knife and awl handles for the hand tools I sell. The .75 x .75 x 6" blanks I use for knife handles have rare problems of cracking and checking to to moisture content change. This I can live with. My problem is the 1.5 x 1.5 lengths I use for the Awl handles. I've tried soaking in Preservation Solutions Wood Juice for as long as 3 weeks after rought turning a blank. Even when the part doesn't check or crack on the lathe (a 15-25% loss rate), I can apply finish, assemble the awl, and as much as 2 weeks to 3 months later have the finished awl crack. I've heard that the are folks out there that sell resin stabilised Snakewood. Anyone know of a source??
Re: Need a source of supply
GaryG in MD
>Dave,
I apologize for not answering your real question, but FWIW, you might consider trying Dave Smith's DNA soak. Sounds like you don't have much to lose. You can search for it on this board -- there's a ton of refs.
Hope you find your 'solution',
Gary
Jim Davies, Clayton, NJ
>Here are rwo links that may help you.
http://www.rrpwhite.com/stabilizing%20page.htm
http://www.stabilizedwood.com/price.shtml#customerwood
Jim D.
Peter Toch
>I had similar splitting problems on pens if the wood was not completely dry before turning the pen. Think of it this way. If the wood is at all wet when turned, it will in time continue to dry further, shrink, and since the brass tube won't move with the wood, the shrinking wood has no choice but to crack to releave the stress. You may be experiencing the same phenomenum with your knife and awl handles. I have found a very simple solution to my problem. If I suspect that the pen blanks I want to use are not completey dry, I first cut my blanks to length, bore the hole to receive the brass tube, but before glueing in the tubes I run the blanks in the microwave oven for 3 to 5 one minute cycles to fully dry them out. I wait about one hour between cycles to make sure the blanks have cooled to room temperature and allow enough time for the water vapor that is produced to evaporate. I pre-bore the blanks to facilitate the drying and stress releaving processes. However, I find that as the blanks dry the hole in them can change shape and/or gets a little smaller due to the wood shrinkage. Therefore, I re-drill the hole, glue in the brass tubes and finish making the pens in the normal fashion. And guess what??? No more cracked/split wood on my pens!!!
Give it a try. It's a lot easier and cheaper than trying to find stablized blanks.
Peter Toch
Scott Greaves in Blackfoot Idaho
>Hi Dave,
Snakewood is prone to cracking! Among penturners who use snakewood a lot, boiling is probably the preferred method of reducing the number of blanks lost to cracking. Boil it for a half hour, then let it sit in the water as it cools down. Dry it properly - weeks or months (or in the microwave if you need it quick!). As for stabilized snakewood, the links given you above are as good as they get! Good Luck!
Scott.
